Question about Music
I have a Guitar Research Amplifier Integrated Solo
I have a Guitar Research Amplifier Integrated Solo Tube Series T64RS: Channel 1 (which I assume is the clean channel) will cut in and out and the light will dimmer with it and it makes a fuzzy poof sound each time it kinda goes out. Also it will distort on that channel too. Please help. I do not want to be lied to by a repairs place. I don't have a lot of $. Thank you for any help.
    New Friend:
    Problem Solver:
  • 5 Answers
As far as I can tell from this; you could have either one of two problems.
1. Your guitars output or amps input could be loose. This happened to me with my bass. All you have to do to fix that is get into the electronics (usually accesed behind plates with screws), find where the cord goes and pinch the two clips together to make the fit tighter
2. There could be a problem with your power; which could possibly originate from the socket itself, a loose attachement of the power cable to the amp, or a loose cable inside the amp. Id reccomend plugging some other electronics into the wall and seeing if their power dims, if they dont then plug in and unplug the part of the cord that attaches to your amp and if that doesnt work you'll need to take i in to an expert to look at the internals of it.
Posted on Jul 29, 2013
  • 2 more comments
  • Chris Fernandez Jul 30, 2013
    Both solutions make sense to me (I am not that smart) IF I had problems with Channel 2 too. But I don't. Can you explain that. B4 i open this amp I need to understand a little more. And the power seems fine but I will try another outlet, if i understand why that would only affect Channel 1, not 2. Thank you
  • nicholas pollett Jul 30, 2013
    http://www.solorb.com/elect/musiccirc/ha... The two things in the bottom right of this pictre are what your patch cord plugs in to. Try pushing the long metal part in a little bit because thats what hold your cord in the right place to ge the signal through without cutting
    Thank u that helps alot, but still if the input is not functioning wouldn't it affect the distortion channel too?
    Ya it would. I was assuming the way you where wording it that there were 2 seperate inputs and one wasnt working; but if its one input then theres probaby a loose cord somewhere inside and it would be a good idea to take it to a proffesiona;
4 Suggested Answers
  • 1138 Answers
SOURCE: Channel one doesn't work
The 12AT7 is usually the driver tube for the tubes before it ( the input channels ). It can also be the driver for the reverb or tremelo channel. I'm not sure what model of amp you have or the manufacturer but there are plenty of places to look on the internet for info. http://duncanamps.com/index.htm is a good place to start. If you can't find the schematic for your amp try and find one that is similar to give you some ideas. If you don't have the basic tools like a volt/ohm meter and a capacitance tester. You might have to consider a pro to look at it. You will be looking for resistors and capacitors in the same circuit as the tubes that you originally mixed up. If its a hybrid solid state/ tube amp you will also need a transistor tester. Of course good soldering abilities are necessary and ABSOLUTELY do not work on the amp while it is plugged in and make sure you properly discharge the filter capacitors in a safe and proper manner before touching the circuit. All the info you need to sucessfully do it yourself is available at the library or on the net as long as you are confident in your abilities and first and foremost work in an absolutely informed and safe manner. Hope this helps.
Posted on Jul 16, 2009
SOURCE: my amp has 2 channels, clean and distortion.
I have same problem where distortion works but clean doesn't on same amp. What might be helpful for someone to help me is that sometimes the clean does work.
Posted on Feb 09, 2010
  • 5603 Answers
SOURCE: Hey, the clean channel on my Marshall 250dfx Combo
The switching is done electronically by an analog gate chip. On IC9, check if the signal on pin 8 changes with switching between clean and OD... This is the actual signal that changes the gate. If you don't see a change there of say 5 volts, then the problem is in the circuits that drive this gate. If the signal is there, then the problem is in the clean channel audio op amps or the components around them. Let me know the results of the test.
Posted on Oct 22, 2010
Clean channel distorts after a couple of hours use - then cuts out
Check the power supply voltage and look for a hot component. If it takes a while to bring on the symptom it's probably something getting hot.
Nov 12, 2017 | Fender Hot Rod Deluxe Guitar Combo...
I have a RH50 T amplifier, it had a bit of a bumpy car ride to band practise the other day and now when i play through it, it will make a permanent buzzing noise on the clean channel that gets 70% worse on...
You may have damaged the variable resistors (the volume controls), you can purchase replacements from a local Electronics store (if UK based try Tandy). Otherwise have you checked the speaker itself for damage? You may have split the speaker which will need to be replaced.
May 04, 2011 | Randall RH50T Tube Series 50-Watt Guitar...
My normal amplifier have sound but no amplification made even your gain control is in maximum level ..is there problem in the main amplifier? I need to open the amplifier, this for my first time...
First, don't open the amplifier! There's no user serviceable parts in it. Second, I think what you mean is that your clean channel is working, but the distortion channel is not. This usually means that there is something broken in that circuit. Take the amp to any guitar store and they will be able to tell you for sure.
Mar 02, 2011 | Ibanez Tbx65r Tone Blaster Xtreme Guitar...
Bugera 1960A - channel 2 has very low volume even when vol2 knob is turned fully UP!
The user manual is located at: http://www.bugera-amps.com/PDF/Downloads/1960_P0671_M_EN.pdf on page 5; When the HIGH 1 and LOW 1 (or HIGH 2 and LOW 2) connectors are used simultaneously, their sensitivity is the same (both LOW). This may be your problem however--- Try swapping input chanels to see if the problem follows ther cable or is in the amp.
Assuming it was working before, you may have a short in the cable or a bad component or tube in the amp. Tubes can be difficult to come by. If the other channel works correctly, It may be one of the small tubes. Hope this helps
Jan 04, 2011 | Behringer Bugera 1960 Classic 150-Watt...
My amp is making a high pitch noise almost like feed back. I only use the clean channel.When I tryed the other channel it is not working at all. Bad tube?
Bad tube? maybe
Try removing each tube 1 at a time starting at the first preamp (12ax7) If the noise stops after a particular tube is pulled replace that tube with a known good tube. Shut down the amp between tube pulls, Power tubes don't usually cause this problem but I'd pull them anyway,just remember they get very hot.
Make sure all tube shields are on and replaced after tube pull test
The most common cause of oscillation is a open or leaky filter cap,this would require a cap job and unless you have a good knowledge of tube electronics and the voltage dangers present,I wouldn't suggest doing it yourself.
Also if the output transformer was replaced or rewired or the negative feedback circuit was touched oscillation could occur also.
Make sure your guitar cables are in good shape, a cable with a bad shield can cause problems too.
Excessive noise can occur when one of the 1/4" input jacks shorting bars doesn't make contact to ground. A duumy plug would confirm this but you could also plug two guitars with good cables, into each input and see if the oscillation disappears.
Hope this helps
Nov 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Sound comes and goes on the drive channel, and there is a strange crackling on the clean channel. i dont know if its the tubes, the speaker, or electronics.
Using a common lead pencil, gently tap on the smaller tubes in the unit, listening for noises and crackling to change and the drive channel changes.
It is normal to get a slight twang when doing this from the microphonics of the tubes, however, the crackling and up and down volume points to a bad tube.
Sep 03, 2010 | Fender Hot Rod Deluxe Guitar Combo...
On clean channel when 'channel volume' is adjusted, the sound cuts out, goes completely dead. I have to switch to another channel and back again or switch off and back on. The amp seems to get confused!
When it is working, wiggle the channel volume control WITHOUT rotating. If the sound cuts out, likely the soldering of the pot leads is broken where it attaches to the board. Try resoldering the connections.
SOMETIMES the control is damaged in which case it must be replaced.
Aug 30, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
The clean channel cuts in and out. The drive channel works just fine though. The clean channel also makes a rattling noise when it is working then it cuts out. Whats up with this thing?
This is likely a bad jack for the foot pedal, or a problem with the pedal and cable. The jacks are junk and even with the pedal unplugged the switch contacts on this jack will vibrate and cause your problem.
Jul 19, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Deville 212 overdrive channel making Loud humming noise
It sounds like a filter capacitor(s) has failed. The electrolytic caps dry out and cease to perform allowing unfiltered power to reach the preamp sections and get amplified.
Being this is tube with high voltages, an experienced person should work on it due to shock danger.
I assume you checked the tubes for shorts as well as emission since a heater to cathode short could cause this as well.
Sep 30, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
469 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
