Question about Sony Televison & Video
Sony kdl-37s4000's image went pale
Hi my TV's image turned a pale color today. It works normally except for the image. The image is also normal except for the faded colors to a pale whitish
    Problem Solver:
  • 13 Answers
VUS DEVREZ CHANGER VOTRE ECRAN CAR VOTRE ECRAN NE DONNE PLUS COMME IL SE DOIT
Posted on Jul 28, 2013
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
rhozel2010
  • 269 Answers
SOURCE: Picture suddendly changed to "photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Posted on Sep 04, 2009
SOURCE: My Sony BRAVIA KDL-46V3000 Television has messed
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Posted on Nov 23, 2009
Testimonial: "You were so right. Thanks."
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
SOURCE: My Sony Bravia 46" LCD turns pink randomly
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDL46V3000&news_id=245
Posted on Apr 06, 2010
What has gone wrong with the image on my tv?
The T con board is responsible for what you see and is responsible for bad, distorted images.
Oct 20, 2015 | Sony BRAVIA KDL-40BX420 40" LCD TV
Sony bravia black screen audio ok
It is a LCD set and if sound get it in a very dark room and with a flashlight and the set on look to see if you see a very faint image on the screen.
Almost all these sets use a back light system for brightness---an inverter of some type to power the lights---either the back light is bad or the voltage for it is not present or being turned on.
Nov 05, 2012 | Sony BRAVIA KDL-52XBR3 Television
My Sony Bravia kdl-v40xbr1 has a full screen of vertical color lines
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 25, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
I have a SONY 52"
don't worry, clean LCD panel connector (rub with pencil eraser)
Aug 21, 2011 | Sony Bravia KDL-32V4000 32 in. LCD TV
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Severe color banding and color shifting for skin / hair tones
Think u got some kind of magnetic field interference.Move ur tv set to the right or left couple inches,just make sure not be to close to ur other electronics devices.Go in ur tv menu.Go to PICTURE.Go down to reset,the setting will go back factory setting,so the colors.See if that help.
May 08, 2010 | Sony KDL-46W5100 TV
Video turn pale green/yellow then comes back?
sounds like your picture tube is going out, if its an old tv it would be best to let it die since its very costly to fix these problems. If its new you better get it looked at. It is a hardware problem, nothing you can do about it.
Aug 25, 2007 | Sony KV-36XBR250 TV
Televison & Video Logo
299 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
