Question about Vacuums
Volta vacium cleaner U2715 HP Beetle
Dismantle cleaner to fix on off switch
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
How do i open/dismantle a hoover telios vacuum cleaner ?
Hi there! Disassembling the cleaner beyond detaching the nozzle, wand and hose is not recommended. If you need further assistance we recommend taking your cleaner in to a Hoover authorized service center for inspection. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jun 22, 2014 | Hoover Vacuums
Volta vortex 2200w vacuum cleaner
See if the company will fix it under warranty. If not, you can take it apart and look for the obstruction. It sounds like something is inside obstruction the air-suction flow path. Normally the motor or controller would not cause the motor torque to drop.
Apr 02, 2017 | Vacuums
The motor in the vacuum will not operate. With the unit plugged into power the green light goes on but the motor remains silent. When the power head is attached it does not operate and the lights on...
Vacuum cleaner repair manuals seem rare and difficult to obtain. The instruction booklet does not contain dismantling and repair details because to do so would make them responsible for encouraging incompetent people to electrocute themselves.
Vacuum cleaners are generally fairly intuitive to dismantle and the circuits fairly simple. The switches are sometimes found to be faulty but it would be wise to assume nothing. I once scrapped a cleaner assuming the motor was defective in the absence of other faults but when I had already removed everything but the motor, when I finally lifted out the motor I found a (faulty) bimetal thermal breaker...
May 06, 2017 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Can't disassemble the foot
We can't provide instructions on dismantling the cleaner head, and would advise against attempting to do so as this procedure should only be carried out by a Dyson engineer. Dismantling the cleaner head will also void your 5-year warranty.
If you feel the cleaner head is not working correctly or requires replacement, please get in touch with us directly so we can provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). If it's necessary to replace the cleaner head, this should be covered by our 5-year warranty, as long as the cleaner has been used in accordance with the terms and conditions listed in the user guide.
Kind regards,
Jack
Dyson Online Customer Support
Jul 18, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I have a volta ultima vacuum and the brush won't turn around anymore.
Tip the cleaner up and were the brush is theres a belt it is either slipping or broken replace. Undo cover over brush and undo brush lift out put new belt onto motor and then the brush and reassemble
May 17, 2010 | Vacuums
How do I dismantle an Electrolux Ambassador II?
you don't, as a repairman, even i have a hard time opening them, and then the hardest part is putting it back together.
Sep 14, 2009 | Vacuums
Possable broken/Disconected wire
hope you have checked the obvious first ..the plug are all the conections tight including the fuse? if so check the vac's switch for loose conections .lets face it the mains feeds the switch the switch feeds the motor unless you have a speed switch. sounds like a fault that could be cured with a bit of investigation good luck farr64
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Fitting a new electricity cord
remove the wheels then you can see the screws not easy to remove the wheels they just pull of
Jul 28, 2008 | Dyson DC05 Cylinder Bagless Canister...
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
