Question about Cell Phones
Tere mast mast nain callertune - Cell Phones
2 Suggested Answers
SOURCE: dabangg's tere mast mast do
send me caller tune cod
Posted on Apr 24, 2011
How do you replace the atenna mast for 2005 sierra.
How do I install a new antenna on my GMC 05 2500 Sierra. I have to replace the base because it broke off. I've taken the dash off. But cannot seem to fish wire through the firewall.
Nov 26, 2010 | 2005 GMC Sierra
Power Antenna Mast
easy way permanent mask both ways have to run cable. I bought me the amplified glass ant strip that goes on front windshield. A lot better for my car.
Jan 01, 2010 | 1988 Chrysler LeBaron
How to replace thunderbird antenna
please rate service.
Automatic Electric Antenna
Removal
  1. Lower electric antenna (18850) .
  1. Remove rear retaining screws of RH front wheel splash shield for access to antenna lower retaining bolt.
  1. Remove lower retaining bolt.
  1. Remove radio antenna nut (18865) from top of motor tube and remove electric antenna through fender/splash shield access.
  1. Disconnect signal cable and motor wire connector(s).
Installation
  1. To install, reverse Removal procedure.
  1. Tighten top radio antenna nut to 6-8 Nm (54-70 lb-in).
  1. Tighten lower electric antenna retaining bolt to 5.8-7.8 Nm (51-69 lb-in).
  1. Check operation of electric antenna and radio chassis .
mast
Mast, Power NOTE: A power antenna mast which is bent or broken can be replaced without replacing the motor and tube assembly.
Removal
  1. Remove radio antenna nut (18865) and radio antenna stanchion (18919) .
  1. Loosen retaining nut inside tube using 14 mm (9/16 inch) socket, and slide nut part-way up mast.
  1. Raise antenna to run plastic drive wire at bottom of mast out of motor. Note direction of teeth on plastic drive wire.
  1. Saw off damaged portion of antenna mast. Remove burrs from mast and slide nut and contact tube off stationary tube.
Installation
  1. With the teeth on the plastic drive wire facing toward motor on antenna, push end of plastic drive wire of replacement mast assembly down into tube. Push it around curve at bottom of tube until end enters drive mechanism.
  1. Run motor down while pushing on plastic drive wire until about 305 mm (12 inch) of wire has been drawn into the tube. Stop motor and insert bottom of antenna mast into tube. Lower mast.
  1. Slide contact tube and radio antenna nut down antenna mast. Tighten nut to 0.45 Nm (4 lb-in).
  2. Raise and lower antenna several times to ensure proper operation.
Jul 09, 2009 | 1995 Ford Thunderbird
Service tech's window on a Sharp AR-C260P
You mast remoove 4 screws and take off the back cjver of the mashine
2/ To be shjre? that? tere are no the some cutting peaces of the paper
3. See the papers flag is on correct and did not brocen with the remooving paper///
4/ There are no any coode to reffreshing this mistake
5 you mast visual observe fixin exit unit///
6 it is very ofen problem in copiers and printers///
7 If you a shore? thet the fla jf mooving papar is well, yours machine mast to work well
Mar 22, 2009 | Sharp AL-1641CS Laser Digital Copier
Aerial for the Radio does not close when engine is switched off - buzzing noise heard
The antenna mast (multi segmented metal thing that retracts) probably has a bend/kink in it.  Lucky you if it does, because you can just replace the mast.  This is much easier than replacing the motor.  Do it soon to avoid burning out the motor, or unplug at the antenna motor if you are going to wait.
If the mast doesn't fix it, then it must be the motor, the dealer MAY be able to take back the mast if you keep the packaging,  they will NOT ever take back electrical components,  but the mast is just mechanical.  Anyway the mast shouldn't be more than $30-40, it's cheaper and easier than the motor.
Nov 01, 2008 | Mazda Tribute Cars & Trucks
Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Apr 03, 2008 | Car Audio & Video
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
