Question about Acer Aspire 5733-6607 Intel Core I3-370m 2.4ghz 4gb 500gb Dvd/-rw 15
Why does my laptop keep shutting down?
My laptop shuts off at random unexpectedly
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 96 Answers
Lot's of possibilities, Either your laptop has Virus, or the processor over heating, means it will probably need to di-assemble and replaced heating compound.. called thermal paste..
Posted on Oct 16, 2013
Samsung Laptop Shuts Down Unexpectedly
CHECK THE FANS! The biggest enemy to your laptop is HEAT! You just replaced the display it's very possible you inadvertently disconnected the cooling fan. Clean it while you have it apart dirt and dust prevent proper cooling
Jun 28, 2017 | Samsung Computers & Internet
Why does my laptop keep shutting down unexpectedly?
This is likely due to overheating. Use some canned air and blow out the cooling fans and heat sinks on the bottom and back of the computer. In worse case scenario you will need to take it to a repair shop and have them open the case and clean out the blockage and perhaps re-grease the CPU heatsink.
Jul 28, 2013 | Acer Aspire 5733-6607 Intel Core I3-370m...
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
Asus k52f keeps shutting down randomly
I have seen the odd case where the power supply cannot keep up with the demands when the laptop is running causing it to shut down, but first! remove the main battery to see if that helps, no change! I recommend replacing the power supply adapter in hopes it will correct the problem. Go to www.ebay.com Type make and model of laptop, refine search to power supply and go through the list of prices.
Jul 20, 2012 | ASUS K52F-BBR9 Notebook
Windows keeps shutting down unexpectedly
Your computer is overheating, it is shutting itself down to prevent damage to the internal components.
Your computer should be serviced by a computer technician. He/she will clean the components and chassis of dust. This will increase airflow over the components, meaning your system will be stable and will not shut down unexpectedly.
Take care!
damnor01
Apr 28, 2012 | Microsoft Computers & Internet
MY COMPUTER SHUTDOWN WHILE IT HAS A 60%REMAINING BATTERY. UNEXPECTED SHUTDOWN. MY LAPTOP CANT RESUME THE PROGRAMS RUNNING AND UNSAVED DOCUMENTS AFTER THE UNEXPECTED SHUTDOWN HAPPENS ..WHY MY OTHER LAPTOP...
If the Computer restarts randomly, then the issue might be due to any damaged Operating System Files.
But, if the Computer shuts down randomly, it is due to the Processor.
All the Processors will be designed in such a way that, if there is any overheating issues, the Computer will shut down randomly.
The overheating might occur due to the malfunction of the Cooling Fan in the Computer.
As this is a overheating issue, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan in the Computer should resolve the issue.
Jul 05, 2010 | Computers & Internet
Shuts off (not down) unexpectedly and randomly.
There are many things that cause this issue. On a laptop its often over heating from dust that collects around the cpu fan. This will not be a novice users ideal job. You can take it to the shop to have the laptop tore down and clean correctly or chance damaging it further by trying it yourself. Another thing that causes premature shut down is a program or new driver installed about the same time you noticed the issue. A corrupted execution file will cause this often likely a video driver. Look closely at your exhaust slots where the hot air blow out and looks for dust bunnies.
Dec 29, 2009 | Acer Aspire 5610-4648 Notebook
Dell xps m1330, turns off unexpectedly. i have changed setting in control panel for battery options to turn off never if it is plugged in. it still shuts off randomly.
It could be overheating, and then shutting itself down, to prevent damage.
Restart, and enter SETUP mode, and choose the "System Health Info" setting, to find the internal temperatures.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Buy a can of compressed air.
Follow the directions to keep the can "vertical",
and give a "blow-job" of compressed air into every port and access-door that you can find on the laptop.
You could be surprised at how much "dust" (and dog-hair) that the blow-job removes.
Dec 26, 2009 | Dell XPS M1330 Notebook
Laptop randomly shuts down
This problem might be occur due to old BIOS version installed on the laptop.
If your system shut down unexpectedly within 10-20 minutes while playing games or scanning the system which takes high cpu usages then the problem is of BIOS and try to install the new BIOS version.
for that visit the site of your laptop company.
Nov 25, 2009 | Computers & Internet
Acer aspire 5000 unexpected shutdowns, random, fan running.
Hello
Thank you for using FixYa.
Have you cleaned out the airvents and fan area. these build up with dust and if the unit gets too hot it will shut down unexpected
Also always use on a hard surface so the airvents are kept clear
thanks
Richard
Nov 17, 2009 | Acer Aspire 5100-3357 Notebook
Acer Aspire 5733-6607 Intel Core I3-370m 2.4ghz 4gb 500gb Dvd/-rw 15 Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
