Question about Kenmore 57029 Side by Side Refrigerator
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The door frame around freezer door is very hot -almost too hot to touch- for a long time in side-by-side refrigerator/freezer. The freezer stays about 32F and the frig at 45F. We have unplugged and replugged in the frig and cleared and reset the controls in order to reset the defrost cycle. I checked the defroster in the back of the freezer compartment and it was not on yet the freezer door frame was very hot. I then unplugged the bi-metal strip that controls the defroster and the same thing happened. it is a Kenmore Elite Coldspot 106.54606300 [Whirlpool[. It seems like there is heater/warmer around the door to stop moisture that is running uncontrolled. Is it electric - like a heat tape? What controls it? How do I check this? If it is a heat tape, can it be replaced? How do we access it? The metal case seems to be one large piece. I can't see how to open up between the inner plastic shell and the outer metal covering.
  • 2 more comments
  • jdav Aug 31, 2007
    Thanks for the info. That is very helpful.
    Now that I know it is a pipe and not a heat tape I can look for a cause.
    I cleaned the coils a week ago and they were really blocked up with dust and fuzz.
    I think that the fan in the back bottom that cools the condenser coils is not coming on. I will try to check if it works.
    How often and for how long should the fan run?
    What turns it on and off? a bi-metal strip or a thermistor?
    Thanks for the help.
  • jdav Sep 01, 2007
    Thanks so much.
    I am sure now that this is the problem. A couple of times I tapped the fan and it started right up. I sprayed it with WD40 and that seemed to help some. But I think there are still times the fan is not coming on when the compressor runs. I will replace it ASAP.
    Thanks again.
  • kacmc Apr 21, 2009
    We started having this problem and now our ice maker isn't working? Is this all connected or are those two seperate problems.
  • Anonymous Mar 27, 2014
    The door casing is hot on both doors. The metal stripe in the middle of the door frame is very hot.
  • 183 Answers
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Posted on Aug 31, 2007
  • Tony Coultrip Sep 01, 2007
    The fan in the back near the compressor should run all the time the compressor is running, they are connected in pararell, if the fan is not running it is probably faulty and this would definatly explain your problems.
Had a similar issue with my refridge freezer and sure enough the fan was not spinning. Thanks so much.
Posted on Jul 05, 2010
LG gc-151sa fridge works on. But door frame get hot what is this
Door frame around the freezer compartment is heated to prevent condensation around the door frame during high humidity conditions.
During times that Air Conditioning Or Heating are used in the house, the relative humidity is low and the "energy savings" switch may be turned on - that will turn the heater OFF.
WARNING: if you accumulate sweat around the door frame, you must turn the heat back on to prevent rust and damage to door gasket
Jul 21, 2014 | Refrigerators
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
Exterior of refrigerator between freezer and refrigerator is hot to the touch
It is normal unless there is a lot of dust below your refrigerator blocking airflow. What you feel is hot gas tubes behind the surface of the metal to help reduce moisture around the door frame and door seals that will get hotter should the fan and condenser below refrigerator have a blockage of dust blocking airflow, Sea Breeze.
Jun 17, 2013 | KitchenAid Superba Architect KSCS25INSS...
The top & sides of freezer outer housing getting quiet hot,but only near the door,ps-have the red light alert & rest seems ok,so going to try the defrost stuff.
If you remove the rear panel inside the freezer and examine the evaporator while running you will most times see a few rows of the evaporator with clear ice and the rest will be sweating water droplets. That is what a leak in the Freon will cause and look like. When the door frame gets hot it is sometimes caused by a defective condenser fan or blocked air flow and also reduce cooling. Warm is normal around door frame because you have hot gas flowing there to reduce sweating around doors. I will be here to answer any questions you may have, Thanks Sea Breeze
Aug 22, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
I have a GSS22IBMA GE side buy side. The fridge side works fine but the freezer will not freeze. Also it is hot around the the door frame of the freezer sometime quite hot.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Sep 08, 2011 | GE Refrigerators
Freezer door does not close properly
inspect the seal all the way around the door. check to make sure that it is not in a bind when you open and close the door. if it is you can try a little wd40 or silicone spray on the gasket and frame of the refrigerator where the gasket meets the frame. this will help it slide accros the frame better.
if the gasket is bound up and out of shape, you can heat it up with very hot water to straighten it.
make sure that you keep the gasket and the door facing clean. spillage from the use of the refrigerator/freezer can cause the gasket to stick especially at the bottom.
Jul 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
May 27, 2009 | Refrigerators
Refridgerator top freezer exterior wall hot
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kenmore 57029 Side by Side Refrigerator Logo
3,060 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
