Question about Sewing Machines
Husqvarna claire The bobbin keeps getting the thread mangled
  • 7 Answers
SOURCE: Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Posted on Nov 17, 2008
kent581
  • 87 Answers
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 18, 2009
  • 201 Answers
SOURCE: Husqvarna bobbin thread jamming
Make sure the bobbin thread "clicks" into the tension slot. However, thread nests underneath are usually caused by the top thread, not the bobbin. Make sure your thread is seating itself in the top tension disks. To do this, put the spool on the machine, pull off about 12 or 15 inches of thread, then hold this thread down with one finger on your right hand as you take the thread tail through the threading path with your left hand. When you get to the needle, tug the thread (still holding it down up top) to be sure it seats in the tensions disks. You must also have the presser foot UP while you do this to ensure that the tension disks are open. Watch the first thread guide after the spool as you sew to make sure the thread is not jumping out of there (a common problem with Des1 machines, fixed with SEs - no comfort to you and me!). I have put a small piece of tape across there with the end turned back on itself so no sticky bit is going to catch on the thread.
Posted on Mar 21, 2009
ladydijjmp
  • 9 Answers
SOURCE: Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Posted on Jun 30, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
My topaz 50 keeps birdnesting when trying to sew fmq
Hello
Please re-thread sewing machine from thread spool to needle, making sure that all thread paths are engaged; especially the take up lever and tension area.
Check that the correct bobbin is being used and that it is properly positioned in the bobbin case. Double check that the bobbin thread is in the thread patch and has "clicked" into the spring.
Happy Stitching
Sewingirl/
Jan 27, 2014 | Husqvarna Sewing Machines
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
May 04, 2011 | Husqvarna Freesia 425
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
The bobbin keeps jamming up and is not catching
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 05, 2010 | Husqvarna Freesia 415
Viking husqvarna classica 100, thread tension
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
Husqvarna Vicking - The bobbin thread is knotting
Good luck.
Dec 04, 2009 | Husqvarna Viking 1
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
Can't bring up the bobbin thread
Sounds like hook/needle timing is off. Check it by doing the following with the power off:
remove bobbin, bobbin case, and needle plate.
Make sure using only Husqvarna Viking bobbins.
Make sure the bobbin is unwinding in the correct direction.
If you are still unable to sew, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 27, 2008 | New Home HF-2022
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
