How to delete the call log on blackberry q5 - Computers & Internet
Place to unlock blackberry q5 in rio de jeniro
Hi. You need not go anywhere to unlock your Blackberry Q5. You can unlock it safer and easier from your home itself. All you need to do is visit MobileUnlockSolutions.com submit the required details and get the accurate unlock code for your Blackberry Q5. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Blackberry Q5 with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry Q5 should then be unlocked.
Jul 09, 2014 | Cell Phones
Tip
Blackberry tips: How to delete call log history ?
You do not want your partner know that you spoke with his ex-lover, at 3:00 last night? Delete history log of calls on the <b>BlackBerry Storm</b>.<br /> <ul> <li>Open the messaging application.<br /></li> <li>Press the Menu button. <br /></li> <li>Tap to display the folder.<br /></li> <li>Select <i>Phone Call</i> <i>Logs</i>. <br /></li> <li>Press Menu. <br /></li> <li>Tap the Delete Prior. <br /></li></ul>
on Dec 14, 2010 | Cell Phones
I need a free unlock code for blackberry Q5
Hi. I couldn't find any reliable free unlocking solutions for a blackberry Q5. Some of the available free offers were looking to be scam. So it is better to get the accurate unlock code from any legit source. for example, You can visit TheUnlockArena.Com to get accurate unlock code for your Blackberry Q5 at affordable cost with easy unlocking guide. Good luck.
May 31, 2014 | Nokia 1600 Cellular Phone
Unlock blackberry Q5
Hi free unlock code is not available for your mobile. So better you can go for paid unlocking service. I would suggest this site Unlocking4u.com here you can get the unlock code and unlock your mobile. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
Unlocking4u.com
May 31, 2014 | Cell Phones
Someone has locked my Q5 blackberry screen
Hello Oscar,
In order for you to unlock your Blackberry Q5, it implies that you will loose all the data and information on it. The only way to have your data and information intact is to unlock it with the actual or correct password or passcode. If you probably know the person that locked it, as him/her for the password or passcode, but if you don't know the person, then your device will have to reset itself back to factory settings after trying with several passwords which are not correct.
So to unlock it, it means you have to keep trying to use different passcode till the device ask you to type in the word 'blackberry' for a reset. I advise that you remove your memory card before trying this.
Hope am able to solve your problem.
Thank you.
May 27, 2014 | RIM Research In Motion Blackberry Storm...
Blackberry q5
I tryed wiping my blackberry q5 but it's been wiping for 2 hours now, what should i do?
Jan 08, 2014 | Computers & Internet
How to download metro fm on my blackberry Q5?
You can check Blackberry Appworld if the app is available for download.
Go to Appworld on your blackberry device.
Best regards
Sep 15, 2013 | Cell Phones
Blackberry Pearl 8120 - sms, email and call log being deleted
On the Status screen of the BlackBerry smartphone, the File Free field indicates low ,if the device memory is full then these things will happen on your device,so to never have this problem delete unwanted applications.To delete run desktop manager and select application loader,select the applications that are not frequently used and remove them.Also keep the messages for a month or two because these mails will be there in your mail box.
Jul 20, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Texts and call logs deletes themselves every couple minutes
This is a known software issue on the Pearl, which can be fixed with a software update. You can download the latest software (currently the 4.5 software) from either www.blackberry.com or www.vzam.net/blackberry
Jan 28, 2009 | Verizon Communications BlackBerry Pearl...
SMS messages and call logs being deleted
i had this problem with my phone, the blackberry is deleting all your messages and call logs because you dont have any phone memory, so your phone deletes everything it thinks isnt important.. so delete some of your pics, music or ringtones, and invest in a memory card! hope that helps!
Sep 20, 2008 | RIM BlackBerry Curve 8310 Smartphone
Computers & Internet Logo
353 people viewed this question
David Payne
David Payne
