Question about Encon Industries Dryers
Genie remote model genc-2 installation instructions
I need the installation instructions for the genie ceiling fan remote control model genc-2
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
jmgldsmth
  • 1869 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: Lost Instructions for Hampton Bay remote control 838956
Go to www.kingoffans.com and follow the site. They are the makers of Hampton Bay.
Posted on May 24, 2009
SOURCE: I have a Hunter Ceiling Fan Model # 23529. The
The receiver part #8511204000 and runs like $50 plus shipping....if its the remote the replacement part# 23529-300 and it runs like $40 plus shipping. You can order it from Hunter or other Hunter dealers.
Posted on Sep 03, 2010
SOURCE: When I press the remote
Hi all,my Panasonic Ceiling Fan F-MY143 speed can't be control using remote controller. When remote controller is being pressed, led blinking and a beep sound can be heard. Pls help, thanks in advance.
Posted on Mar 29, 2011
I need to replace the remote, uc 7067rya
You should be able to get a universal remote for a ceiling fan at home depot or lowes. Be aware they only sell then WITH the remote and the receiver unit as a package. Be aware, you'll need to check the 4 "dip pin" positions on the receiver unit on the fan itself to program the new remote. Yes, you'll have a spare receiver left in the package unless you choose to install the new one. You may have to remove the fan to do this, as they're usually found in the canopy (where the fan hangs from the box in the ceiling.) Often, the dip switches are just left all "up," however, they could easily have been changed. Some fans are programmable now, and you can test the code without having to check the receiver in the fan (similar to an older TV remote.) If you're using this for a TV, Satellite dish, etc, you'll need to find a compatible one online (not necessarily that model, it's "UNIVERSAL" and follow the instructions that come with it. TV and Ceiling fan remotes operate totally differntly, so if you have a remote that does both tasks, it's fairly new technology, and you'll have to follow instructions for the one you purchase.
Feb 13, 2015 | Universal Remote Control Hampton Bay...
How to attach and wire my controller for my remote control
What model do you have? If it is an add-on remote, then follow instructions here:
1) Black on end of receiver to black in ceiling.
2) white ( next to black ) to white in ceiling.
3)Other White to white in fan.
4) Black to black in fan.
5)Red or black w/ white stripe to blue or black w/ white stripe.
Oct 16, 2013 | Hunter 52" Ceiling Fan With Light And...
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
Instruction for a hunter remote model 27157
this is the hunter technical support--1-888-830-1326 just ask for support. then you should be able to order the instruction manual.
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
How to set acsctg type 2
There is a button on the motor head you can press. Press it then press the button on the remote 3 times and try it. If not try it again. Genies are bad for not coding in the first time. Make sure there are new batteries in it. Thanks BB
Jul 19, 2010 | Genie Company IntelliCode GICT390-1BL...
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
10.27.09 - Ceiling Fan Light Kit not Working.
the remote does control the light. i think it's the bottom button, once to turn it on, again to turn it off. there should have been a blue wire connected in to the wires in the ceiling, this is power for the light. if only the white, black, and copper are connected, the light part won't work but the fan will (usually)
Oct 28, 2009 | Hunter 52" Ceiling Fan With Light And...
I need to install a Hampton Bay ceiling fan Model AC552 but I have no instruction manual. Can I be emailed one.
look into the internet for download of that manual model with the full name of product for instruction manual. try that.
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
Dryers Logo
144 people viewed this question
Top Encon Industries Dryers Experts
Dan Webster
Dan Webster
Are you an Encon Industries Dryer Expert? Answer questions, earn points and help others
