Epson stylus 4300 scanner rattling
Hello When I on my epson stylus 4300 scanner making tuk tuk ratting noise and stops after few seconds. can anyone help me to fix this
tigertail
  • 163 Answers
SOURCE: service manual for epson stylus dx4000 series
You could try here:
http://www.2manuals.com/product_reviews_info.php?products_id=792&reviews_id=150
Posted on Mar 16, 2009
YourZEN
  • 820 Answers
SOURCE: Epson Stylus CX8400, Printer, Copier, Scanner. Need manual.
Manual for Epson Stylus CX8400:
Quick reference guide in pdf-format can be downloaded here:
http://files.support.epson.com/pdf/cx84__/cx84__qr.pdf
An overview of all documents and manuals on this site:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=90342&prodoid=63069506&category=Products
Posted on Aug 20, 2009
JackHeath
  • 1049 Answers
SOURCE: My scanner :makes a loud noise when trying to scan or copy
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I need more information to offer a definitive solution, but I can give you some information that might help diagnose the problem.
Unless you forgot and tried to use it locked…then unlocked it after, it seems unlikely that changing the ink could directly affect anything related to the scanner. So especially if it still scans and now just makes more noise then before, we can reasonably say it isn’t a faulty locking mechanism and that the gears are probably not stripped, which would either stop it or not. So you’re looking at either something simple like the gear assembly being dry, shifted slightly, etc. or the safety by the lock that makes noise to tell you the device is locked is stuck somehow. The one can be tested by removing the little plastic safety that makes the noise when the scanner is turned on and locked; the other you might be able to test with some WD40 and see if it runs quieter.
Posted on Aug 24, 2009
Testimonial: "I was trying to use it locked...I unlocked it and now it works fine, Thanks"
seanpwright
  • 2030 Answers
SOURCE: Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Posted on Aug 27, 2009
  • 60 Answers
SOURCE: installing epson scanner model cx 4300, without cd
Go to this website and download the software for free. Just make sure you pick your operating system.
http://driverscollection.com/?H=Stylus%20CX4300&By=Epson
Posted on Sep 16, 2009
I lost the cd epson stylus cx 4300
you can download the driver for your epson stylus cx4300 from:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cyrA1FE2Kk6d68TKZC9NhDO&tc=6
Please make sure to rate this solution.
Let me know if you have any other questions. Thanks.
Jan 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My new toyota yaris dashboard is rattling. help!!!!
This is some work that needs your first hand observations.
You must take the car to a difficult rrough road to simulate the noise/rattle , identily if within the dash or if the vibration is a transfer from the steering section or the suspension.
Make someone drive while you observe, identily and find the rattle point to tighten or replace the part.
Oct 28, 2010 | 2008 Toyota Yaris
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Installing epson scanner model cx 4300, without cd
Sep 16, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Aug 24, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
95 people viewed this question
k24674
jasbo
jasbo
