Saeco aircon manuals
The sign of cooling system
2003 jeepm liberty what fuse is for ac compressor
Hello you can download the manual here:
http://www.jeep.com/en/owners/manuals/
Select year and model, and download the manual.
You will need a free PDF reader to read the file content:
http://www.adobe.com/downloads.html?promoid=KAWQL
The aircon system has to be filled up once a year or to be checked the level in the system. If low level in the system, its not cooling.
Almost every auto repair shop has the machine to fill up the system again. This is not a do it your self job.
This will cost around 200 dollars, but only if not something else is malfunctioning, electrical or mechanical.
I recommend to visit a specialist in aircon system, for better and cheaper fault finding.
Good luck
Aug 28, 2013 | Jeep Liberty Cars & Trucks
Air conditioning smells
the heater core has a leak in it and yes it can get into the aircon system as its in the same system
May 28, 2013 | Porsche Cars & Trucks
Aircon not cooling, aux fan not turning, fuses OK heating Ok ,system has been regased
If the fan that cools the condensor is not working then the aircon will not work .
Dec 02, 2012 | 1995 Mercedes-Benz E-Class
My car said "engine hot
Full coolant level does not mean your engine cannot overheat. You need to fix the problem as overheating will destroy the engine if not addressed.
The radiator cooling fans must be working, as must the water pump. The thermostat must also be working properly.
There must also be no air in the cooling system as air locks will impair water flow. When cooling systems are drained fully or partially and re-filled air in the system must be bled out using the correct bleeding procedure for the particular engine/cooling system. Failure to do this properly will lead to overheating.
If you ONLY see the overheating warning when running your aircon you need to check that the electric radaitor fans are kicking in at idle when you switch on and run the aircon and the engine has been warmed up some. If they do not start operating when the a/c is running you will get an overheating condition in normal driving conditions.
If the radiator fans are operating normally and you still get an overheating warning when the aircon is on or off the most likely culprit is a faulty thermostat in the engine's cooling system which will need to be replaced.
If you have either a faulty thermostat or if the water pump in the cooling system fails you will get continuous overheating whether the aircon is on or off.
Sep 05, 2011 | 2006 Chevrolet Impala
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
My car overheat when im using the car aircon,it doest overheat when im not using the aircon,so how can i use the aircon with out overheating my engine,i already clean the radiator,condenser,check the...
The cooling fan should run continuously when the A/C is on. If it does then I suggest you drain and flush the cooling system, and replace the thermostat. Fill it with a fresh supply of a 50/50 mix of antifreeze and distilled water.
May 16, 2010 | 1999 Suzuki Vitara
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
1996 audi a4 aircon problem
You have a leak most likely, and these are typically hard to spot without test equipment. Take it back to your technician and ask him to recharge the system and perform a dye test to locate the leak. Could be as simple as a bad o-ring in a fitting, or as complicated as a seal in the compressor.
Jan 05, 2010 | 1996 Audi A4
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
