How to change resolution on emerson LC320EM1F manually ?
2 Suggested Answers
  • 5187 Answers
SOURCE: HOW DO I HOOK UP AS A COMPUTER MONITOR EMERSON LC320EM1F
The Emerson LC320EM1F has an HDMI connector (HDMI 1) that can be connected to a computer with an HDMI out or a DVI out. With a DVI connection, you will need a ferrite core on the HDMI cable. You can use a DVI to HDMI cable or a DVI to HDMI adapter with the appropriate cable. You will also need a 3.5 mm to RCA (M/M) audio cable (or the adapters and cables) if you want to use the TV speakers. If you have only a VGA output on the computer, you will need an analog to digital converter (like this: http://www.startech.com/AV/Converters/Video/VGA-HD-with-Audio-to-HDMI-Format-Converter~VGAHD2HDMI ).
You can find the manual for this TV including the connections here: http://www.emersonaudiovideo.com/support/download.php . Enter your model number and then the list of manuals will appear. The connection to computer diagrams is on page 13.
Once you have your cables (you will get the best prices from an online shop), turn off both the computer and the TV. Connect the cables then turn on the TV and set it the HDMI 1 input. (Use the Source button on the remote. You can also press CH Up repeatedly.) Then turn on the computer. If your computer has a recent version of Windows, it should see the TV automatically if the port is active on the computer. For a laptop, you will need to change the display settings to use the TV monitor. Right click on the desktop (anywhere there are no icons or programs), find the Display properties option. Set the monitor option to use the second screen (extended or monitor only). Click Apply and confirm the setting on the pop-up. (These are Win7 directions; other OS versions will be similar.) For a desktop, you may need to go to the Screen Resolution option after right-clicking. (This is a shortcut to the Control Panel Display settings window. Thus you can also click Start > Control Panel > Display to get to the right area.)
Some machines may need the port enabled in the BIOS first. This applies more often to older laptops or those with a power-saving option that turned off unused ports. You will need to enable the port with a different monitor active before connecting to the TV. Accessing the BIOS varies but usually involves pressing Esc, F1, F2 or F10 repeatedly after you turn on the computer. I often miss the timing; just turn off the computer and try again if the OS loads or the log-in screen appears.
If you get an unknown mode message on the TV, the previous monitor may have used a refresh rate and resolution that the TV can't understand or the TV was turned on after the computer was turned on. If it's the second case, press CTRL-ALT-DEL twice or turn off the computer (you will see a warning that Windows was improperly shut down). Then turn on the computer. If you have the first issue, go to the previous monitor and use the Screen Resolution directions above. Set the refresh rate to 60 Hz. Set the resolution to 640 x 480, 800 x 600, 1024 x 768, 1280 x 768 or 1380 x 768. (The options will be limited to those that are compatible with this monitor.)
I hope this helps.
(Note only HDMI 1 supports a computer signal; the other ports will not understand the computer's video output.)
Posted on Jul 17, 2012
How do I reset my Emerson LC320EM1F
Have you done a channel scan? Do you have a cable box?
May 31, 2016 | Emerson Televison & Video
Emerson lc320em1f TV won't turn off
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 09, 2016 | Emerson Televison & Video
WHAT UNIV. REMOTE IS COMPATIBLE WITH AN EMERSON FLAT SCREEN TV MODEL #LC320EM1F
There is a whole list of compatible remotes for Emerson here: http://www.compare99.com/compare.html?q=emerson-remote-controls&ort=Universal-Remote-Emerson&adid=iaCkp5630ZqomNPVxJ1fhcbP0qWXWdDNoIagnNfH1aSTn460yJ6hp8aPqJ6XpdTR0VelcMjD2KRYlsnD1W6n&gaa=U&gclid=CPPNg5zy3coCFQWUfgodpAUA_A
Feb 04, 2016 | Emerson Televison & Video
How can I get a full picture on my TV?
Buy a programable remote with a format button on..after programming for your tv..use the format button to change the screen size
Aug 15, 2014 | Emerson Televison & Video
I need a base for an emerson lc320em1f
Contact the authorized dealer for Emerson.
Jan 06, 2014 | Emerson Televison & Video
Remote lost, how to manually change from tv to dvd?
Are you using a cable/satellite tuner to change channels?
Look for a "input" button on the TV.
Aug 10, 2013 | Emerson Lc320em1f TV
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
No picture on emerson loc320emif
Show a torch light on the screen from a safe distance, when program runs. If you can see the picture, the problem is with the backlight and might require the attention of a qualified service technician.
Aug 01, 2012 | Emerson Lc320em1f TV
I hope this helps.
Jul 16, 2012 | Emerson Lc320em1 TV
I have emerson lc320em1f tv but no remote, need help changing ratio
For my Comcast, One for All remote the code was 0171 for my Emerson 32" LC320EM1F TV from Walmart.
Sep 22, 2011 | Emerson LC320EM8 32 in. LCD TV
Televison & Video Logo
227 people viewed this question
Top Televison & Video Experts
Electro Med Services...
