Question about Electrolux Washing Machines
I have a electrolux EWD 1477 what dose e84 mean?? It is also stopping mid cycle
2 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: Hi Ihave an electrolux EWD 1477 washer/ dryer. It
Drainage problem. If it is a new installation the possible causes can be:
- The drainage hose is too deep in the drain (can only be max. 10 cm. in the drain, and the drain height may be a minimum of 30cm and a maximum of 80cm from the floor);
The drainage pump may be blocked (clean it);
- The drain is clogged.
You will LOVE Electrolux for this... Go to:http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
....and click on START ANIMATION for a complete explanation of how you clean the filter on your machine
Posted on Jun 23, 2011
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error E90 and starts beeping and stops working? Any ideas how to fix it ? Thanks kindly
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
Feb 12, 2015 | Electrolux EW1000i Front Load Washer
Error code 1477 on Miele T8322 Drier. What does this mean?
not sure bout the code. but it seems to indicate that the dryer is shutting down at certain heat levels. Thus u may have issues with ur cycling thermostat or thermal cut off or even ur venting and duct system.
Jan 28, 2015 | Miele Dryers
My Electrolux Front Loader stops mid cycle and then resets back to the start! It cannot finish a load?? There are no error messages being didplayed!
This may be a circuit board problem whenever it tries to reverse spin or drain some of the water...
what type and how long a cycle ....or does this happen with all cycle options?
Apr 15, 2014 | Washing Machines
Electrolux washer dryer ewd 1409 start and pause light keeps flashing
That is a generic error code - please reset the unit at the household circuit breaker for about 10-15 minutes, and then retry the unit. No difference - please consult a professional.
Aug 22, 2012 | Electrolux EW1000i Front Load Washer
Hi I actually have an EDW 1477 washer/ dryer. I keep getting an E20 message, the machine then beeps and stops! Any idea what the error is and what I should do? Thanks
This is a problem associated with the drum not emptying water - usually a blocked empty pump filter. Electrolux have an excellent support site. Go to:
and click on START ANIMATION for a walkthrough of what you need to do
Jun 23, 2011 | Electrolux EW1000i Front Load Washer
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error 20 (E20) and starts beeping and stops working? Any ideas what it could be? Thanks kindly
Jun 23, 2011 | Electrolux Washing Machines
Electrolux washer stopped in mid cycle with clothes in will not empty water out. What do I check. Brian
Most likely something caught in the pump. Coins and balls of lint are real common.
Sep 17, 2009 | Washing Machines
Electrolux W375E
if you go to electrolux laundry systems you will be able to download the operating manual for the W375N. all error codes are on this PDF doc..
Nov 26, 2007 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
