Question about Hardware & Accessories
Straight pipe muffler - Hardware & Accessories
4 Suggested Answers
  • 623 Answers
SOURCE: why does the muffler make a popping sound it ...
This is what's called an oxymoron. Because with straight pipes there is no muffler! Haha. Sorta like Jumbo Shrimp.
But the cause of your popping sound is because of afterburn in the exhaust system. With no back pressure because of the straight pipes, some of your engines' combustion is happening in the exhaust. That is a super way to burn a valve BTW.
Posted on May 26, 2010
  • 70 Answers
SOURCE: my muffler system there is 2 or 3 emission part in
The only component that must stay in place to pass federal emissions is the catalytic convertor. If you are not concerned with emissions then a straight pipe will be fine. There will not be any adverse performance problems with a straight pipe. Please rate my help this helps me out , Thankyou RJ
Posted on May 30, 2010
  • 302 Answers
SOURCE: MUFFLER CAN YOU RUN STRAIGHT PIPE GO WITH OUT
I have done that in the past and it ran a whole lot better by getting rid of catalytic convertor.
Posted on Nov 14, 2010
What exactly is muffler drone?
an un baffled exhaust noise
causes the drone
resonators explained
How Mufflers Work
that set up has no back pressure on the exhaust manifold
almost straight pipe system
I didn't have this problem when i was running my factory mufflers and resonator.
you took out the resonator
Oct 30, 2016 | Dodge Cars & Trucks
Tip
DIY Replace Back Muffler / Resonator with Straight PipeSubject: DIY Replace Back...
DIY Replace Back Muffler / Resonator with Straight PipeSubject: DIY Replace Back Muffler / Resonator with Straight Pipe
Title: Increase Fuel MPG by Replacing Back Muffler
Overview:
When your back muffler fails, and or if you want a bit more gas milage, replacing the back muffler with a straight pipe seems to work fine and increase MPG. This is much cheaper than purchasing a back muffler with DIY or to have a local customer shop install a straight pipe.
Symptoms:
Back muffler failing, onion peeling and / or holes in the back muffler.
Experience Level:
Medium
Tools Needed:
Hack Saw, Ratchets, Wrenches, etc.
Time Needed:
About 1 hour:
Parts Needed:
Pipe parts from local auto store. Exhaust sealers, hangers, pipe tip (stainless)
Procedure:
Remove the back muffler by cutting the pipe before the muffler about 2 inches in front of the muffler. Replace with straight pipe components or have a shop do it. You will need some time to get it 100% right. It took me a couple of tries.
Outcome:
- Money savings in replacement.
- Slightly louder, but not much. Actually a better sound (subjective)
- 1-5 MPG gas savings, especially on open road.
Discussion:
I have done this on a 99 9-5 I4 for about 1 year now and it seems to be working fine. I am getting about 3+ MPG on the open road since this was done. It is an automatic with 140k miles solid 29-30 MPG with regular fuel on the open road. I really do not see the need for the back muffler / resonator at the present time.
I will be doing this on a 2001 V6 wagon soon. The muffler will be failing soon.
on Jan 17, 2010 | Saab 9 5 Cars & Trucks
2003 Saturn vue v6- excessive water, moisture dripping out of tailpipe- same vehicle that's making the roaring noise
Water does drip out of the tailpipe as a matter of course. That's perfectly normal.
If you have a 'roaring' noise from the silencer/muffler area it's probably because there's a hole in it due to age/corrosion and the exhaust gases are leaking straight to atmosphere without being silenced by the muffler.
Water WILL drip from a holed silencer or pipe. This is normal. The water isn't your problem - you have a hole or split in the muffler or pipe
Mar 21, 2016 | Saturn Cars & Trucks
Exhaust question 93 silverado 5.7l 350. Singlr pipe Think its 3 inch pipe. There is no cat. On it and the muffler is cracked down the middle. Should i put a new muffler/glasspack in for performance reasons...
If you have no catalytic converter and replace the muffler with a straight pipe,, you WILL NOT BE ABLE TO HEAR YOURSELF THINK!!.. I took the converter off mine and it was SOOO loud.(have a Flowmaster dual outlet).. It WAS TOO LOUD.. I put a 28" "glasspack" inline..WHEW.. I can actually hear the radio now!!!
Flowmaster Mufflers
Jun 28, 2017 | Cars & Trucks
My muffler system there is 2 or 3 emission part in the pipes from the exhaust to the muffler. can a straight pipe rplact those 3 piecies?
May 30, 2010 | 1994 Ford Aerostar Extended
Why does the muffler make a popping sound it ...
May 21, 2010 | Motorcycles
Exhaust Pipe broke/Rust on muffler
Flex pipe will work, or if it's a straight section of pipe you can buy a universal piece of exhaust tubing with flared ends, trim off the rusty ends on your original pipe with a hacksaw or Sawzall and slip in the new section. Clamp it with 2 muffler clamps and you're set. Total cost should be under $40.
Apr 10, 2010 | 2000 Saturn L-Series
Is there a honey comb baffle in my system ,if so can i chissle it out with out many problems and will it increasr the power i dont have...she is gitless
Cold air intake and straight pipe. Baffle would be a smog pipe. Looks like long bullet pipe. I would just use this and no muffler. Or get turbo muffler, and no cat or no smog.
Mar 23, 2010 | 1994 Ford Ranger Supercab
96 grande cherokee 6cyl. replaced o2 sensor and code still shows bad sensor so changed out again thinkjhg it was faulty but code still shows bad sensor.Drove for while and back fires to the point were...
Sounds more like an ignition misfire. Sometimes also, an exhaust leak in the pipe above the sensor can add enough air to cause the mixture in the pipe to ignite and cause the same problem. The first "weak point" in the exhaust is the muffler which is why it blows it up. Cutting out the cat will not solve this.
Oct 28, 2009 | 1996 Jeep Grand Cherokee
Hardware & Accessories Logo
290 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
