Question about Fujitsu AMILO PC Laptops
Disable internal pointing device
I cant shut down my laptop, when i open the lid,it shows internal pointing device enable.
How do I re-enable my accidentally disabled keypad?
It may have been turned off in the BIOS/Setup
If so, how to re-enable:
Turn computer off.
Turn computer on. Immediately press F2.
BIOS screen comes up.
Press right arrow once to move highlight to "Advance" on the upper tabs.
Press down arrow to move highlight to "Internal Pointing Device"
Hit "enter" to turn it from "disable" to "enable"
Press right arrow over to highlight "Save and Exit"
Press enter
May 02, 2015 | ASUS VivoBook S550CA-DS51T 15.6"""
How do I disable the touchpad? I am running Vista Home Premium. There is no Function key to enable/disable the touchpad. I disabled the touchpad by going to Control Panel, Mouse, and disabling the...
have u gone to control panel - device manager - then on pull down menu's show hidden devices ; click on all the + boxes till you see touchpad ( mouse and pointing devices) right click mouse and click on disable.
i always go through device manager as all devices are in one place!!
Apr 11, 2015 | Gateway M-6827 Notebook
How do I disable the internal microphone on a Dell e6400?
Hi Jamiescoffee,
You may want to follow the below steps to disable Microphone:
(1)Right click on the speaker icon in the status bar.
(2)Select Recording device.
(3)Right click on Microphone array and disable it.
However, if you want to enable this later on you may just right click on the same screen and select show disabled device. Right click on the device and enable it.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jan 05, 2015 | Dell Latitude E6400 Notebook
Hi, i hav a probook 4510s laptop & i cant get the mouse pad to work... when the lappy is starting up, in the left hand top corner is says - no mouse detected. please help!
If this is a recent occurance, shut down, unplug, remove battery, plug in, push the on/off button and do a System Restore to a date before this problem. Perhaps the TouchPad driver is in error. You can try a external USB mouse to troubleshoot the problem in Device Manager to verify the driver or device isn't in error. I think HP TouchPad software is Synaptics Pointing Device, check your your Tray Notification Area for the icon, right click, select Pointing Device Properties. Or Control Panel, select Mouse.
Nov 29, 2013 | HP ProBook 4510s FM849UT Notebook
Mouse didn't detected
Touch pad usb or wireless mouse ?
Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs. Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time. Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard. Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse. This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function. Press and hold the "Fn" button together with the mouse icon button. Look for the disable/enable symbol that briefly displays on your screen. Slide your finger over the laptop's mouse and attempt to use it as normal. Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter." Press the left arrow key to navigate over to the "Device Settings" tab. Press the tab key to reach the "Enable" button in this section. Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box. Press the space bar to remove the check mark. Put your finger on the touchpad, and move the pointer down to the "Apply" button. Click "Apply" to save the settings. Close the mouse "Properties" box. Press the keyboard "Windows" logo key to open the "Start Menu." Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart." Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function. Open the "Control Panel." Go to the "Add and Remove" or "Uninstall" programs section. Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse. Select the "Uninstall" option to remove any software and settings associated with this secondary mouse. Restart your computer and attempt to use the built-in laptop mouse as normal. Check to see if the mouse is working properly. Press the keyboard's "Windows" button to open the "Start Menu." Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel." Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it. Find "Mice and other pointing devices from the list" and open its "Properties" dialog box. Select the "Driver" tab and choose "Update Driver." Allow Windows to search the Internet for drivers and to update them automatically. Restart your computer after the drivers are updated, and use your mouse as normal.
Beginners Guide to Using a Computer Mouse? Tips and Tricks
http://tips4pc.com/basics/beginners-guide-to-using-a-computer-mouse-tips-and-tricks.htm Laptop not working - touchpad unresponsive http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Apr 14, 2013 | Acer Computers & Internet
I have an advent modena, and it seems the drivers for the cd rom has been disabled because i cant locate it in device manager and drive slkmvyre FVFC "DS8C4S" shows its disabled. the CD ROM cant...
just matter of interest , check the bios setting, goto device manager and delete the CD Drive, reboot, still the same problem then it a hardware issue,
the drive could be jammed.
Aug 20, 2011 | Advent Modena M101
Toshiba laptop touchpad not working
Most likely your problem is that the touchpad was disabled. Enabling/disabling could be done in two ways:
1. press Fn and F9
2. in control panel, mouse, you will find the option regarding enabling/disabling touchpad (in some machines called internal pointing device)
Aug 07, 2011 | Toshiba Satellite L655-S5101 Laptop
Insirion E1505: Missing Wi-Fi device
I would not open up one of these animals if I could avoid it! Go to the bios, "Disable" the Wi-Fi. Re-boot and ensure NO Wi-fi AT ALL in "Device Manger". If you have the software for the Wi-fi (May be on the System disk that came with the machine) go to "Remove Programs" and take out any software for this device. Shut down completely. Leave for a couple of mins. Re-start and go into bios. Re-enable Wi-Fi and re-boot. re-install software IF requested. Good Luck! Ian.
Sep 28, 2009 | Computers & Internet
Disabled internal mic on toshiba satellie A200
I've just had this problem and fixed it.
Right click anywhere in the "Recording" tab of your sound options. (the place where you disabled this mic) and click "show disabled devices".
Then simply enable it. Hope this helps.
Feb 11, 2008 | Computers & Internet
Fujitsu AMILO PC Laptops Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
