Question about Comtrend CT-507 Router
Accessing router hi aatif i have a problem i changed a host ip but entire networ is not working
  • 2,961 Answers
If you have changed the ip address of the pc that is connected to the router, then the router can no longer see the pc because you have changed it manually, you need to change the router back to DHCP enabled to allocate ip addresses automatically and change the properties of your network card to obtain ip address automatically. This way all the pc's will be given ip address to share the network.
Posted on Sep 01, 2007
In my house i have a laptop with wired internet, 1 wii with wireless, 1 wireless access point. now i'm trying to get internet on my phone using wireless. however i forgot the network password. how can...
Some wireless routers have a web management page hosted by the router where you can change the password. You can access this by typing in the router's IP into the address bar on an internet browser. To get the IP of the router, on your PC, go to Start -> Run -> type cmd -> then type ipconfig /all. This will give you information on the network adapters on your PC. Find the entry "Default Gateway", this is your Router's IP. The router will ask you to authenticate using an account you set up along with a password. If you do not have these either you can access the admin account with a default password if you haven't change the admin's password. Here is a list of those. If you can't find you router or this does not work, most routers have a button on there exterior that will perform a factory reset. Hold the button down for 5-30sec and it will reset the router back to when you first bought it.
May 08, 2011 | Computers & Internet
Virtual Server / Port Forwarding does not work from within the Local Network
When you use port forwarding in Virtual Servers and try to test it from within the local network, it may fail. When for example, port 80 is forwarded to a web server in the local network, you may get the router's home page instead of the web server's one or you may get nothing at all. When you try to use the server from outside the local network it will work fine though.
This can happen when you try to access the router's WAN IP address from within the local network. In order for port forwarding to work from within the local network, the router needs to support a feature called NAT loopback. This is not a part of the specification of Belkin routers and modem-routers, so most of them will not have the feature, and if a router does have it, it is not supported.
In order to use the server from within the LAN, you can address it by its internal LAN IP address (e.g.
If the WAN IP address has a DNS host name associated with it, such as, and you need to use that name to connect to the server, you can do so by associating the name to the local IP address in the hosts file (a file called hosts with no extension). This file lists IP addresses and host names and is used before actual DNS lookups are done. You can add lines to the hosts file using a text editor like Notepad on Windows. The lines look like: # comment
The lines contain an IP address and one or more host names separated by white space. Anything that follows a hash sign is a comment and will be ignored. You will need to change the hosts file on all machines in the LAN that need access to the server.
On Windows, the hosts file can be found in C:\Windows\System32\Drivers\Etc on Windows XP, Vista and Windows 7, in C:\WinNT\System32\Drivers\Etc on Windows 2000, and in C:\Windows on Windows 98 and ME. You need to have administrator rights to edit the file; on Windows Vista and Windows 7 you need to run Notepad as administrator.
on May 05, 2010 | Computers & Internet
Remote Access
IF you are getting public ip from your isp, please go to administrator tab of the router and first change the router's password which is on the top on same page in black dots,,type your new password by deleting old one and re-confirm it just below and save it..router will prompt for the new password just to let you know settings are saved now enable remote managment option on the same page and port is 8080(default, you can use your own port number) and save you are ready to access your router remotely for that note down the public ip you are getting on your router's status page and in remote location you need to type something like :- http://x.x.x.x:8080...x.x.x.x is your internet ip (public) and 8080 is port number for remote management.
For host applications need to know which application you are running according to that need to open port in the router using Port Forwarding feature of the router.
Jul 15, 2010 | Linksys Wireless-N WRT150N Router
Remote access DVR through dydns
the host name does not reside in DNS. Try accessing with the external public ip address
Jan 20, 2010 | 2wire 2700HG-B Router (2700HGB)
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
1. go to dos prompt
2. type "nslookup"
3. type "
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Motorola Router Help
Well the only way you will get the main page for the router, would be to type in its ip address o its specific http address. Make sure that you are typing in your web pages Http address. i.e. rather than an ip address. You will need the domain address if you are hosting the website on your computer. typing in the ip will simply tell it to go to your router login page.
Apr 16, 2008 | Computers & Internet
Hi Kingpin,
You need to access your router admin function by typing the IP address of your router in your Inernet Explorer Address line.
Then enter your username and password at the router authentication screen. The go to the tab for "Applications and Gaming". There you can configure your Specific Application's ports, protocol and IP.
Nov 29, 2007 | Linksys Wireless-G WRT54G Router
Networking issues
Hi gymny,
The best connectivity in hosting application is using virtual ip network. Normally DHCP always changing IP in everytime your computer reboot or shutdown.
Hope this will be helpful to your problem.
Best regards,
Oct 17, 2007 | Cisco (WS-X3011) Router
CyberXLink CXL-EBR-W router - can't open ports 5631/5632 for pcAnywhere
Hi dave, I'm not familiar with that router at all and I didn't find any doc's online for it so I'm running blind here but... If the router has it make sure "Block WAN Request" is disabled or you won't get anywhere. Also I don't know if the print server has anything to do with your problem. Have you tried mapping those ports directly to the host in the router? TCP PCanywhere port 5631 Inbound 192.168.1.[host IP] port 5631 UDP PCanywhere port 5632 Inbound 192.168.1.[host IP] port 5632 I'm also assuming that you're using a static IP on the host. You don't want to use a dynamic IP. Hope this helps. Let me know how you make out, Duder
Nov 17, 2006 | cyberxlink (CXLEBRW) Wireless Router
Comtrend CT-507 Router Logo
155 people viewed this question
Top Comtrend Computers & Internet Experts
Julie Endres
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
