Canon Pixma MG-5250 : paper will not feed into the printer (just get a loud thumping sound)
SOURCE: Canon Pixma MP160 paper will not feed
try the feed button which is usually on the front of the machine. press once
Posted on May 22, 2008
  • 6 Answers
SOURCE: Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
Posted on Jun 12, 2008
SOURCE: Loud clicking sound
We had the same problem, with a slightly different solution... it turned out in our case that the new toner cartridge's internal drum was too stiff, so the printer was trying to turn the toner spindle and failing, resulting in the clicking noise. Our solution was to manually turn the black center gear by hand a few times, and in doing so loosen the drum up a little, so that the printer could turn it. We put it back into the printer, and voila! No more clicking noise.
Thanks to whitehorse1 for his (or her) solution... though it wasn't the exact same problem for us, it was what put us on the right track. :)
Posted on Oct 18, 2008
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
How do i remove jammed paper in my canon pixma 5250 please
Look for FAQ ID: 8200816500 in Canon web site
Please make sure to check all places for paper jam. You can click on the website below for illustrations/instructions for removing all paper jam:
Canon PIXMA MG5250
Oct 11, 2016 | Canon Office Equipment & Supplies
How set set up type of paper (plain, photo,..) on my Canon Pixma MG 4150?
The type of paper is selected through the printer dialogue in the operating system. The "Control Panel" in Windows or "System Preferences" in OSX.
Jan 20, 2013 | Canon Pixma MP500 All-In-One InkJet...
I have a new Canon MG 5250 printer, I loaded a full width but too short piece of paper to print, now says paper jammed but I cannot see any paper, how do I unjam paper
here is the procedure on how to remove paper jammed.
http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MG_series/PIXMA_MG5250.aspx?faqtcmuri=tcm:13-776431&page=1&type=faq#Paper Is Jammed inside the Machine at the Transport Unit
Apr 27, 2011 | Canon Office Equipment & Supplies
Canon Pixma MP780 makes a loud clicking noise. No paper jammed anywhere. It seems to be the gears where the cartridges are.
i have th same exact problem, just took much of it apart, bu still cant see why it makes the loud noise, also I cant switch paper feed to back, which at least would allow it to print from there... please let me know if you find a solution.
Nov 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Keep reading have no paper yet when I add paper it still say to load paper. Also there is a clunking sound that has developed lately.
PIXMA MP620 has 2-way paper feeding. Check your proper paper feeding. Rear feed or bottom cassette paper feed.
Jun 10, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I have a Canon Pixma iP1700 printer. When I try
This is a common issue with all printers and faxed. Try to clean the rollers and use different paper weight
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Oct 01, 2009 | Office Equipment & Supplies
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
My printer will not feed paper, when it tries to
the rubber rollers that feed the paper might be dusty so the paper slips
May 17, 2009 | Canon Pixma MP500 All-In-One InkJet...
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Mar 11, 2009 | Canon Office Equipment & Supplies
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
23 people viewed this question
k24674
jasbo
jasbo
