Question about Ovens
Smev 4 burner gas grill oven 12 volt - Ovens
3 Suggested Answers
SOURCE: Hi, I have a Jenn-Air gas oven SEG196, with the
The part is AG200. Don't know where to find it.
Posted on Feb 08, 2010
heatman101
  • 43501 Answers
SOURCE: Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Dec 27, 2010
Gas valve wont open in my oven
call your local repairman .
Nov 15, 2016 | Ovens
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Smev Oven and Grill 401 instructions
the grill element appears to be broken. I have removed it and it is not attached
Oct 04, 2011 | Ovens
I have a Webber Q Family BBQ for about 2 - 3years. I noticed say last 6 months that the burners are not working properly and the grill is not hot enough ie take 3 times longer to cook a steak etc. I read...
OK, it sounds to me that when you changed the propane tank, you may have turned the gas tank valve on too fast. Doing so causes the built-in excess flow valve to check, which only allows a trickle of gas through. Do this: Turn off the gas tank, disconnect it and drain any remaining gas from the grill by opening a valve to a burner. Close the grill valve and then reconnect the tank. Very slowly open the tank valve and try lighting a burner again and see it that solves the problem. Douglas
Sep 12, 2010 | Ovens
I have a gas oven that is a couple (4-5) years old. I hit the bake button, hit 350, hear the click or tick and that's it! That's where it ends no "whoosh" of gas or flames afterwards.
check the voltage to the gas valve in bake cycle if the 12/24 volt is there then change the gas valve if not voltage is present then check the tranformer circuit and limit switch to the gas valve
Jan 22, 2010 | Ovens
First two burners, now all burners...
You have a defective spark module. This is a device which breaks down the 120 incoming volts to a 12 volt spark to ignite the burners. Replace module and problem should be solved.
Sep 01, 2009 | Jenn-Air JJW8530C Expressions Collection...
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
How do you light a gas oven
Chances are your hot surface ignitor is bad. Take off the bottom panel inside the oven you will have to removes grills also. You will see a center beam under the panel that is where the flames of your burner are. The hot surface ignitor is right there at the start of the burners. As a test turn the oven on and notice it hot surface ignitor glows. If it didn't glow then it needs to be replaced. Easy fix only held on by two small screws 1/4 size nut runner and two wires. You will have to cut the wires as they run back into the back of the oven. The new one just take the wire nuts that come with it and attach. Don't make the wires too short as you will need the length. let me know how it goes ken
Jan 11, 2009 | Amana AOGD2750 Gas Double Oven
Oven & hob taking a long time to come on(on FULL pressure)
Hello mick1939. Are the ignitors the clicking/sparking type or the glow bar type?
If they are the glow bar type, when they get older they don't send enough amps to the gas safety valve thus only letting a small amount of gas to the burners. Try replacing them if they are glow bars.
Nov 30, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
