Panasonic kx ft937
Hi when we are sending fax to others receiving fax will half blank sheet please give me solution to solve Thanks Shan
  • 82 Answers
SOURCE: Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Posted on Apr 06, 2008
jon_than21
  • 30 Answers
SOURCE: Faxes are incomplete or non-existent for Panasonic KX-FPC166
check the cover if it has been closed properly, if not check the cover lock and hinges.
Posted on Jul 25, 2008
  • 215 Answers
SOURCE: Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Posted on Apr 13, 2009
greg_margo
  • 1959 Answers
SOURCE: Panasonic KX-FL521 Fax Laser Copier, New Toner
This is usually an indication that the toner cartridge wasn't shaken from side to side to distribute the toner evenly.  If this was done, the cause is probably a dirty drum.  Remove the toner cartridge and clean the drum. Either of these two solutions should solve your problem.  Best of luck.
Greg
Posted on Jul 09, 2009
mostak321
SOURCE: clear memory fax on panasonic kx-ft937
fax does not transmit and receive.
Posted on Nov 26, 2012
COMMENT UTILISE FAX PANASONIC KX-FT937
My comment is that you should. Hope that's helpful!
Please ask a SPECIFIC QUESTION if there is something you need.
Apr 25, 2014 | Panasonic KX-FT937 Thermal Fax Machine
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
CAN'T SEND OR RECEIVE ANY FAXES
HI.when u try to receive or send any fax.fax gives any msg r not.first check ur telephone line.u have to connect it in line.there are two places in fax .one is ext and second is line.check it u r putting it line.for receiving check auto answer .put it on fax only mode.u will receive fax.MIAN AKHLAQ.if it helps rate the solution.
May 16, 2009 | Panasonic KX-FPG381 Plain Paper Thermal...
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Jul 16, 2008 | Panasonic KX-FPC95 Plain Paper Thermal...
HELP!!
Face down. Blank side up. It doesn't matter which edge you send first.
Apr 18, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Document sent is blank for recipient
Hi there check the machine scanner light by putting the original in the feeder and doing a copy. If the printout comes out OK then it either could be the other fax machine you are trying to send it to or you have a intermittent fault with your scanning lamp (Section).
You also must make sure that the original is text face down.
Hope this helps you
Thanks J
Jan 08, 2008 | Panasonic KX-FP121 Plain Paper Thermal Fax
22 people viewed this question
k24674
