SOURCE: i dropped my android tablet
You can get the part at android Repair and there is a guide that shows you how to put in the part at tablet Repair Guide.
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
My tablet pc is stuck on the start up screen an will not go any further what should I do
SOURCE: Onda v711
You need to perform a
hard reset on your Onda V711. Here`s how:
You can perform a hard reset by booting into a special recovery mode.
First, ensure your device is fully shut down. When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
If that fails, try flashing new firmware.
