Question about Dryers
A combo,gfic switch
Whant use the light switch 2 turn the motor on and off need help
    New Friend:
Send me new base nut
Posted on Jul 29, 2013
Florescent ceiling light on the garage ceiling will not go on
If the GFIC trips all outlets wired from it will lose power also. Check your wiring. You should also remove switches from the circuit containing outlets.
Dec 04, 2013 | Dryers
Electric pressure washer will not start
CLEAN FRESH WATER IS IMPORTANT FOR THESE PUMPS, I ALWAYS USE A HIT OF ARMOR ALL IN THE PUMP AFTER USE . YOU MIGHT SEE IF IT'S GETTING POWER TO THE MOTOR MIGHT HAVE A BAD GFIC ? PLUG IT IN PICK UP THE UNIT AND TRY DROPPING IT FROM A FOOT OFF THE GROUND, THIS JAR MIGHT SHOCK IT BACK TO LIFE ?
. Jay the pool pump whisperer FLORIDA 32750
Sep 21, 2012 | Karcher K5.540 2,000 PSI 1.4 GPM Electric...
Wiring a GFIC outlet to a single light/outlet
Copy following link for wiring diagrams of GCFI wiring:
http://waterheatertimer.org/How-to-wire-GFCI.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 10, 2012 | Electrical Supplies
I live in an old house and im changing a single switch to a switch and receptacle combo and i have wired it every way to sunday the light works but the receptacle either does not or it also turns on light ...
Open following link for specific wiring illustration and tips.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
Single pole switch has 2 wires: These wires are Hot wire from breaker, and wire going to Load (light).
Combo device needs additional neutral wire.
Without a neutral wire, the combo outlet will not work.
Neutral wire connects to silver-colored screw. Neutral wires are the white wires that are twisted together and covered with wire nut and pushed to back of electric box.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical outlet or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Cooper Industries Cooper Wiring 274W...
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
Mar 07, 2011 | 1995 Kia Sephia
Show wiring diagram for 274w combo
1) A wiring diagram can be mistaken because wire colors vary.
That's why electricians don't guess, they test.
2) Look at device to be replaced and note what color screw each wire goes to before disconnecting wires.
If old device is single pole switch, then there are 2 brass screws, and one of these screws is connected to Hot wire, and the other screw is connected to Load wire (light, fan, motor, pump)
3) Separate wires inside box for testing.
Do not untwist any wires.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot. Hot wire connects to dark-colored screw on combo device.
4) Hot is identified.
Test Hot to all other wires, except bare ground wire.
Tester lights up on Neutral wire. In a single-pole switch box Neutral wires are usually twisted together and covered with wire nut. Neutral wire connects to silver screw on new device.
5) Load wire that goes to light,fan, motor, pump connects to brass screw on new combo device.
6) If you do not have a Neutral wire in your switch box, then outlet will not work.
You can connect bare ground wire to silver screw and have outlet work, but this is not code, and definitely not recommended for a child's room or any room near water pipes or faucets or metal pipes of any kind. You need to add a Neutral wire and/or install GFCI protected device for any bathroom area.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Feb 05, 2011 | Cooper Industries Cooper Wiring 274W...
I have an outlet that I want to convert to a light switch and an outlet on the T5625. I can not get the light switch to work. I have a Black hot and neutral with a grond. how do I hook up ht light portion?
Electrical devices have color-coded screws.
Electricians don't guess, they test.
You have tested the wires.
1) Combo switch-outlet device screws are dark - brass - silver - green
Hot to dark
Neutral to silver
Load wire (wire that goes to light, fan, motor) to brass
Bare ground to green screw
2) If you want switch to control the outlet on the combo device.
-Device must have 2 dark screws
-Look at dark screws, there is a break-away fin that connects dark screws.
-Remove break-away fin.
--Now there is one dark screw for the switch part of device, and one dark screw for outlet part.
-Connect Hot to dark-for-switch.
-Run jumper wire from brass screw to dark-for-outlet.
-Neutral to silver
-Switch on combo device will operate outlet on combo device
For a price, expert speaks with you over phone while you work on wiring or any do-it-yourself project.
Jan 16, 2011 | Leviton Decora Combination Switch - 5625-I...
Dryers Logo
24 people viewed this question
Top Dryers Experts
