Insert sim jumper
SOURCE: insert sim
Hi have a repair shop, and you know it’s a very common problem on this model. 90% of the cases I found liquid damage in the phone damaging the Sim Ic, it’s a little square one near your sim reader, you can also clean around that with a soft tooth brush and mentholated sprits. Don’t fiddle with your sin contact/ reader if no damage visible to the eye.
SOURCE: 1600 insert sim problem tips tricks
hello
try this site http://4free-mobile.blogspot.com/2008/11/jumper-tricks.html
you will find everything that you want
SOURCE: samsung champ gt-c3303 insert sim solution image
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
