Question about Ovens
Germanio oven looking for the specifications for the Germanio oven 900
Is electrolux oven better than lg
What features and size are you looking for? Electrolux is most popular for its cooking product line and they are one of the most efficient and highest ranked manufacturer's in the kitchen. Are you looking for a specific design? Electrolux is more European where LG is trying to make their designs reflect high tech computer designs.
Aug 15, 2012 | Electrolux Ovens
Oven will not turn off
Ok, I see this often, when the self clean function is used, it basically heats up to about 700 - 900 degrees, sometimes the Thermistor, thermostat, goes faulty after this is done, most likely that's the problem. Below is a servicing manual. Or call a professional and have them take a look at at, it is most likely a simple job, hopefully.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6342e2edf7772b6e852573440054cfc6?OpenDocument
May 05, 2010 | Whirlpool RBS245PDS Electric Single Oven
Oven locks after self cleaning After self cleaning the panel indicates locked
I believe they can stay "Locked" for up to 3/4 Hours. See they heat up to like 900 Degrees, to "Clean" the oven... It stays locked until the oven "Thinks" it is "Safe" to be opened.
Feb 10, 2010 | Ovens
Blodgett mo # 981 will not start all the time
http://www.blodgett.com/Literature/Manuals/Deck/900-man.pdf
Go to this site for an owners manual.
Please be alittle more specific.. Are you saying that the burners do not light? Is there a pilot?
Jul 30, 2009 | Blodgett Ovens
Need to adjust clock setting on Stoves 900 GDO Stoves 900 GDO gas double oven
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Mar 06, 2009 | Stoves Ovens
I'm looking for an instruction manual for a Stoves 900 GTF built-in fan assisted main oven. Can you help?
Let me have an email address for you and I will give it access on my BT Digital Vault for you to down load a copy that I have scanned.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Stoves oven genus 900 error codes
Hi phill6x6...try turning on the oven by the main button, and press and hold button 7 until it beeps. Hope this helps you, and a few others!!
Nov 18, 2008 | Stoves 720EF Electric Double Oven
Thermador SM272 - Oven not heating after self clean cycle
Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Sep 23, 2008 | Thermador Professional Series PO301...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
