Manual for Sherwood Receiver Model RX-1010 - Audio Players & Recorders
welcomejee
  • 10594 Answers
SOURCE: I have a Sherwood RX-2030R,
Check Sherwood RX-2030R specification of AM tuning frequencies limits in user manual.
Please confirm was it tune before below 1320 and above 1710 AM meter band?
Posted on Nov 06, 2008
  • 4234 Answers
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Posted on Apr 12, 2009
  • 7 Answers
SOURCE: sherwood rx-4109 power shuts off
The output transformers may-be gone
looking at +$50 AUS
for just the parts
or a licensed service
for about $150 AUS
Posted on Apr 16, 2009
  • 30 Answers
SOURCE: trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Posted on Sep 20, 2009
    calmeblondy
    • 33 Answers
    SOURCE: Looking for instruction manual for sherwood
    http://audio.manualsonline.com/ex/thread/view/idThread/401393
    ck this site , should solve your problems
    Posted on Sep 28, 2009
    How do I connect my RX-4109 to a Crown power Amp?
    If your Sherwood has preamp outputs, you can connect directly to the power amp inputs.
    Sep 13, 2014 | Sherwood RX-4109 Stereo Receiver Black
    I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
    You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
    Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
    Does the sherwood rx 4105 receiver have analog or digital inputs
    Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
    Feb 12, 2013 | Sherwood RX-4105 Receiver
    What is a compatible turntable for my Sherwood rx-4109 receiver?
    many decks have pre amps or need preamps. hence the reason why you have distorted sound i would guess. you need the opposite of what you used. What record deck did you try?
    Jan 06, 2013 | Sherwood New-RX-4109 STEREO RECEIVER WITH...
    I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
    Cables between sources and compatible units rarely need to be physically modified.
    Register and download the manuals for free at retrevo.com
    http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
    http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
    Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
    There is NO other volume-controlled output to choose. Try it.
    Mar 25, 2011 | Sherwood RX-5502 Receiver
    FM Tuner in Sherwood RX-4105 stopped working
    Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
    If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
    If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
    Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
    Dec 02, 2008 | Sherwood RX-4105 Receiver
     Grubhead
    Grubhead
