Question about Aiwa AV-DV75
Won't Power Up
Unit started flickering on and off repeatedly and then would eventually stay on until one day, it doesn't even turn on anymore. Help!!! Thanks.
  • 1 more comment
  • zingo156 Jun 12, 2008
    aiwa av-d35u reciever unit keeps flickering on and off will not turn on please give ideas...
  • jeffaie Jun 29, 2008
    he may not but I am
  • gb-computers Jul 13, 2008
    Problem Solver:
  • 9 Answers
I just noticed the date of this post, do you still need help, or did you resolve your problem?
Bri
Posted on Jun 10, 2008
  • b0naf1d3 Mar 15, 2011
    i have the same problem red light and clicking sound, can u email me with guided help?
    [email protected]
    thank you
SOURCE:
Monitor won't switch on properly.
This is a common symptom of failing filter capacitors in the power supply board. Over time as the capacitors start to fail they are not able to buildup and hold a charge like they should. The worse they get the longer the start time will be until one day the unit will not start up at all. The repair is easy to do, it just requires replacing the 5 bad capacitors on the power supply board. Here is a link to a parts kit that shows what needs to be replaced on the board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=222
I hope this helps,
BuddyMc
Jul 19, 2012 | Samsung Computers & Internet
I have an JVC HD 56g 787 and it just died. The on/off switch just keeps on flickering. What's wrong with the tv?
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Jul 21, 2011 | JVC HD-56G787 Television
Hyundai L19T : power bottom doesn't work and power led is blinking.monitor screen is black but blinking .
Jul 21, 2011 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
I have a 37" hdtv
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
Jun 20, 2011 | Vizio VX32LHDTV10A 32 in. LCD HDTV
I have the samsung 2232gw computer monitor. When power is connected the blue power light turns on and stays on and flickers. The screen is black and nothing shows. Would this be something small I could...
Jun 17, 2011 | Samsung Computers & Internet
When you turn the tv on it the picture flickers and freaks out and does not stop! Please Help
The solution I am about to provide normally is for units that don't turn on, but if your power supply is failing, the solution still applies to you!
There's a good chance you have failing electrolytic capacitors in the power section.
Any caps in any sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on properly, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
May 30, 2011 | Hitachi Televison & Video
Orange light will not stay on when the tv is off.
replace the power cord, do not use tv till you replace the power cord ok, you will eventually short circuit the tv or even worse blow the internal components
Jun 22, 2009 | Vizio L32 32 in. LCD HDTV
Monitor cold start issue only as #2 monitor
The start up problem is common and will only get worse. Call Samsung as these monitors have a 3-year warranty. No receipt? They will accept your word regarding your purchase. I have two that failed exactly the same way. I called 1-800-SAMSUNG and they gave me the choice of an exchange pair sent directly to my house (requiring a temporary credit card deposit) or by having the exchange pair sent to the UPS store where I would swap out my bad units. No receipt. They merely asked me when I purchased it so they could have it for their records. Manufacture dates such as your (March '06) and a purchase of September '06 are not far fetched at all. .
May 19, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Toshiba a60???
if this happens even if your laptop is plugged in to a power source it could be that your battery is dead and you need to replace it
May 21, 2008 | Computers & Internet
Now the monitor flickers..
Your monitor is slowly dying. Get ready for the eventuality and start saving some bucks for replacement.
Sep 18, 2017 | Mitsubishi Diamond Pro 91TXM 21" CRT...
Aiwa AV-DV75 Logo
435 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
