Question about Vizio M260VA 26 in. HD-Ready LCD TV
Signal problems set plays great even up to a week at a time but then start to see lines in screen followed by blue screen with no signal then set turns off by its self..happens with cable and antenna connections..turn set off and resets for a while..is their a board to replace..
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Posted on Nov 03, 2008
phongnv
  • 56 Answers
SOURCE: My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Posted on Feb 17, 2009
  • 92 Answers
SOURCE: Black showing as red on LCD
this is a LVDS cable issue. All you have to do is call Vizio and they will send out a tech and replace the LVDS cable along with the Main Board. This should resolve the pixilation issue.
Posted on May 20, 2009
  • 10 Answers
SOURCE: VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
Posted on May 23, 2009
  • 19 Answers
SOURCE: How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Posted on Mar 27, 2010
Have 32 inch rca, says no signal, blue screen, plays dvds great has good picture, how do i get tv picture on?
IF plays DVD's via the audio and video jacks on the set there is a option here--bypass the issue with a box (cable or sat or any kind that will pass the signal via the same connections you use for a DVD.
The blue screen suggests you have or may have a bad tuner in the set--cannot beat it get around it.
Jun 11, 2012 | Televison & Video
The start up screen is on with no signal through
Try a firmware upgrade.
http://www.infocus.com/Support/Products/Projectors/IN76.aspx
Oct 24, 2009 | InFocus Play Big IN76 Multimedia Projector
My 2005 WD62725 just started getting wavy lines on it. Everything works good (i have picture and sound and all functions) but the lines started first only when a non-HD signal was coming in. Now it has...
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Cannon ZR60 lines on screen and in viewfinder
I purchased a dry head cleaning tape and used that. I followed the instructions and now it is fine :)
Dec 17, 2008 | Canon ZR60 Mini DV Digital Camcorder
Mistubishi Convergence/video display problem
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 26, 2008 | RCA P56923BL 56" Rear Projection...
Blue Screen
Please clean the Head with a Head cleaning Cassette and try again
Oct 14, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
BLUE LINE
call philips to get this srviced under warranty. this repair might take a few weeks because the failure could essentially be any one of several parts. first thing to try is the ssb, then the logic board and lvds cable. if none of these work then you need a new panel
Sep 12, 2007 | Philips Magnavox 42MF521D/37 Television
Screen now showing blue line at bottom
Sounds like, you have a bad optical block. Part can cost $550 to $800 + labor
Mar 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Vizio M260VA 26 in. HD-Ready LCD TV Logo
26 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
