Question about LG LRFD21855 Stainless Steel French Door Refrigerator
Interior Light The interior refrigerator light will not go out. Any idea what is causing this?
  • 2 more comments
  • bdrnem Aug 30, 2007
    Are you talking about the buttons that turn off the light for the door switch?
  • Anonymous Aug 12, 2008
    The lights will not go out and the plastic is melting.
  • fire4n6 Aug 14, 2008
    Same problem, but intermitant. Twice the lights have failed to turn off and caused distortion to lens. I noticed that when this occurs you can hear no sound when the door switch is pushed in. When it works properly, you can here a clicking sound coming from somewhere when the door switch is pushed in. (possibly a relay?)
    Today, my secretary informed me that her Kenmore made by LG just did the same thing and caused burn damage around the light fixture. Seems to be a pattern here!
    I unscrewed one of the bulb to reduce the amount of heat available when it happens again.
  • pawleysdawg Sep 02, 2008
    The interior lights will not go off and there are signs of heat damage around the plastic casing. I have pushed in the switches that allow the lights to come on and go off but nothing happens. For the time being, I have unscrewed the bulbs. What is causing this problem?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The lights are controlled by the main board. You need to get a new board. You should also lower the wattage from 60 to 40
Sgt 40
Posted on Jun 08, 2008
Try and reset the door switch by pushing it down once or twice and confirm
Posted on Aug 30, 2007
SOURCE:
Light inside both fridge and freezer are flashing strobing
Maytag refrigerator control panel lights are flashing and the ...
www.shopyourway.com > Manage My Life > Questions
Maytag refrigerator control panel lights are flashing and the ice door opens and ....Took an hour or two since it was my first time taking the interior panels apart. ..... myfridge to what you suggested i buy (even thought both are 35V) and for the ...
Whirlpool Refrigerator Repair - Interior lights flicker ...
? 3:24
https://www.youtube.com/watch?v=0s4aQYNWzZs
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot a Whirlpool Refrigerator that has this following dilemmas: Interior lights flicker Only at http ...
Nov 02, 2015 | Computers & Internet
Phillips fidge model 71-357c light for interior
Is there a model number posted in the refrigerator?
Nov 14, 2012 | Refrigerators
Interior light stays on...light is hot..food directly beneath light is not cooling
HI. There is a door switch that controls the interior lights. This switch is also connected to the fan motor circuits. The actual door switches will be the lone culprits in your case. They are not functioning at this moment. This switch fault will effect the cooling process and cause an abnormally high temperature inside the unit, due to no Evap fan action and interior light heat.
Simply replace the door switches to correct the issue.
Sep 04, 2010 | Viking DDBB363 Bottom Freezer Refrigerator
INTERIOR LIGHT GOES ON AND OFF
next time it does this unplug for 20 mins and pcb will reset its self....
Sep 28, 2009 | Hoover HFA290K Bottom Freezer Refrigerator
Interior light does not turn off
Hi, try this  There s this knob that gets pushed when you close the door (the door puhses on it when it closes) and the light goes off
you can do it yourself, open the door and find the knob somewhere around the light or on top where the door closes and push it, the light should go off..
Pls rate my solution.. thank you
Apr 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
No interior light
check the touch wire on the rear view mirror one of them may be cut
did u check if the lamp work well?
Jul 06, 2008 | 1994 Volvo 850
LG LRFD21855 Stainless Steel French Door Refrigerator Logo
178 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
