Question about Radio Communications
JVC KW AVX-820 bluetooth problems
My KW-AVX820 used to pair both the handsfree and audio transfer automatically with my Blackberry 9100, one day it just started only pairing the audio transfer and the handsfree pairing fails, it works sometimes but very rarely. I tried resetting the JVC with the reset button and also removing the battery pole in the vehicle and killing the power to the stereo, deleting the pairing and Re-pairing the 2 devices, and changing the encryption the settings on the BB. Don't know what else to try
SOURCE: My Motorola H700 Will Not Pair
I had the same problem and I keep trying and trying 1234, 0000 and other numbers I can think of. It was frustrating. I was ready to throw my device away and buy a new one. Then I tried something that I have not and it worked. All I needed to do is to press the big button in the center of the H700 until it turns purple steadily. And then I pulled out the microphone of the H700. The button remained purple. Then I typed the password 0000 into my cellphone. The button will flicker indicating it's finally communicating and then it finally did!. Try that. Hopefully it works for you too. It worked with mine.
Posted on Jul 03, 2008
  • 125 Answers
SOURCE: Purple light wont stay lit for pairing
Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
Posted on Jul 11, 2008
  • 1019 Answers
SOURCE: Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Posted on Oct 06, 2008
dougjr76
SOURCE: jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Posted on Feb 08, 2009
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Posted on Feb 20, 2009
I can't see anything on my jvc kw-avx820 indash. Everything on the screen works fine. The USB stopped working the same day the screen went out, idk if that has anything to do with it. Noticed that you
standard solution if it does not work is to check for power and ground.
replace unit if both are present. Going further find out if there is a place that has a checker for your model and maybe save some money. The USB is probably the input for display so you might take apart to see if anything is out of place.
Jan 23, 2013 | Car Audio & Video
Reasons for black screen on jvc avx730 and how to fix it
sudos dispongo jvc kw-avx820 funciona la radio pero la pantalla no se prende gracias
Mar 09, 2011 | JVC KW AVX820 Car Video Player
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
KW-AVX-810
was simple i got in touch with as i do not have a manuel got lost some how so i got the diagram and was able to solve the problem infact its got a usb port at the back of the unite just pluged y ipod usb in
thanks
Jul 30, 2009 | JVC KW-AVX810 Car DVD Player
Radio Communications Logo
35 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
