Monitor won't power up or down. Green on/off light flashes, but won't turn off or turn on. Screen is black. Seems like monitor screen flashes a bit at the same time the green light flashes.
Tried unplugging the unit and when plug back in the same thing happens - flashing green light and nothing on the screen.
Computer did have an error code on when shutting down and froze. Had to hard shut down the PC. When first brought PC up, the monitor indicator light was on (green), then started flashing when I tried shutting it down and rebooting.
-   Apple Cinema HD Display - 23" TFT active matrix Flat panel display w/ USB hub, I plugged it in and the monitor won't come on the power light flashes once and the screen stays black. Suggestions? -   Guest
Apr 05, 2009
-   My Mag innovision LT773s has a black screen and a green flashing power light. My computer seems to churn away and will not power down. Since I cannot see on the screen what it is doing, I don't know if the problem is the computer or the monitor or both..-   Guest
I turn on the screen then within a few seconds, horizontal white lines flicker and the screen goes...
(More)
I turn on the screen then within a few seconds, horizontal white lines flicker and the screen goes off. I turn it off then on again and it does the same thing.
