Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
I need to replace the center point on my Motorizr Z3 cell phone.
DI need to replace the center point on my Motorizr Z3 cell phone. Do I need to order the entire center front housing or can I just get the center point button that glues on?
  • Anonymous May 30, 2008
    how do i replace the center buttons?
    Brigadier General:
  • 7,752 Answers
You have to get the entire keypad replaced not just the middle
Posted on Mar 28, 2008
SOURCE:
How to replace the motorola rizr z3 outer navigation slide small
http://modmymoto.com/wiki/index.php/Razr_v3_Full_Housing_Change
follow the steps given in this site... think it ll help u out to change ur mobile's housing
Feb 22, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorizr z3
yes the LCD can be replaced take the phone to amobile service center and have it replaced
Jun 24, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Same problem need clarification
Pros: There are NO Pros
Cons: There are Many Cons
Same issues here after 3 phone replacements by them T-Mobile
Also I thought I was the only one having issues with Z3 Phone but not, check out Motorola RIZR Z3 forum at http://www.phonescoop.com/forums/search.php?q=Motorola+RIZR+Z3
Z3 turns OFF itself while talking, taking a photo, video or checking messages.
It will also reboot while just sitting idle.
Major Lint issue on behind the main display
Mar 29, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Can Someone help me
YOU WILL NEED TO TAKE THE PHONE TO A MOBILE SERVICE CENTER OR TO SOMEONE THAT HAS THE KIT TO UNLOCK IT FOR YOU....OR ONLINE www.mobile2mobile.net or www.gsmok.com
Mar 28, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Subsidy codes for motorola
try www.mobile2mobile.net or take it to a mobile service center or take it to a person that can unlock them for a small fee....
Mar 09, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorizr z3 speaker
you need a special software to make the phione ring louder....but it is best to take the phone to a professional mobile shop ad have the techs there raise the volume for you on the phone.
Dec 28, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorizr z3 mute call
When you are on a call, press "Options" then "Mute Call"
Dec 07, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Dust under motorizr z3 screen
From
http://www.mobile-phones-uk.org.uk/motorola-rizr-z3.htm
Richard from UK
WARNING - DO NOT ATTEMPT THIS IF YOU ARE AT ALL UNSURE, AND DO NOT ATTEMPT THIS IF YOU DO NOT WISH TO RISK VOIDING YOUR WARRENTY!!!!! Turn off your phone, flip up the front panel and place the phone face down on a soft surface. Use a Torx T5 screwdriver/bit (available from some hardware/electronics stores or online) to carefully unscrew the small screws from the reverse of the front panel. Do not loose these!!! If you turn the phone over you should now be able to lift the top of the front cover away from the display, then slide down slightly to free it from the bottom of the display. Be very careful at this point as there is a small ribbon cable connecting the front cover buttons to the rest of the phone!!! This can be unplugged from the display board by carefully lifting it away, you may need to use a small screwdriver to gently lever it up but in my case this was not necessary. Now use a blower brush (available from any good camera shop) to blow away the dust from both the LCD display and the inside of the front cover. Then simply reassemble the phone by following the above instructions in reverse. Voila - dust free Z3!
Oct 30, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
94 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
