Question about GE GSD5610D Dishwasher
'drying' light comes on with audible alarm
When starting the cycle, DW starts then the drying led comes on with alarm. DW will not finish cycle. Manual suggests the Sequence Switch. Found one at local parts shop for $63. Will try this unless you have a better idea or suggestion to prove the switch is bad?
SOURCE: ge dw gsd5940
there is a piston nut in the back under that screen,.... check into replacing it.
Posted on Apr 14, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
  • 205 Answers
SOURCE: Heated dry and normal wash flashing, also beeping.
hello mam please check the timer and internal wiring.
Posted on Oct 24, 2009
  • 1140 Answers
SOURCE: My GSD3600 GE Dishwasher will
Hello Greg,
Your diagnosis is pretty good, but the buzzing suggests it may be the capacitor for the pump motor that has failed rather than the pump motor itself. The capacitor phase-shifts the AC current for starting the motor.
The drain pump should run briefly at the start of any wash cycle to clear any residual water from the washer and this appears to be where the failure occurs. The metal rod you can see moving is the actuator/linkage from the solenoid which opens the valve to the sump inlet. This doesn't start the motor and it appears to be working correctly.
You need to test the motor and/or determine where the buzzing noise is coming from.
This is an updated part from GE and may look slightly different to the one fitted in your washer, but all of the components are the same. The solenoid actuator you can see moving when you press start is ringed in blue on the left, the capacitor is the black box on the right, ringed in red and the terminals for the power supply to the motor are ringed in green.
If the buzzing is coming from the black box, you need to replace the capacitor or motor - I'll need to check whether the capacitor can be replaced separately. If you have an ohm-meter, test the motor for resistance/continuity across the two terminals ringed in green. You should get a reading of about 1 to 2 ohms if the motor is good. If the buzzing is coming from elsewhere it may be the solenoid for the water inlet valve.
Please test the motor if you have a meter and try to identify where the buzzing is coming from, then get back to me. You can reply to me by clicking on "Add a Comment" below your question.
Posted on Apr 16, 2011
  • 2510 Answers
SOURCE: Dish washer will not start lights just blink . I
It would seem like it is a faulty switch, a spring inside might have collapsed and the button that should protrude so that the door can activate it, is too low and not making contact with the door. Check the door as well though, that there is not some button or raised part that is not pressing on the door switch to activate it. If you are stuck for a switch at the moment, stick something to the door that will activate the switch until you can get hold of a new switch.
Posted on Jul 13, 2011
  • 45 Answers
SOURCE: When plugged in, dw normal wash and heated dry
Check the door switch
Posted on Sep 18, 2011
0 characters
1 Points
Zanussi diswasher ZDI6053N does not finish its cycle.It has to be turned off manually
Your dishwasher is a sophisticated device that registered most failures. The End of cycle LED flashes if there are alarms memorized. So, count how many times the End of cycle LED flashes.
For example:
One flash - i10, the problem with water intake
Two flashes - i20, a problem wit drain water
Three flashes - i30, activated anti-flooding device
..... and so on
Sep 01, 2014 | Zanussi Dishwashers
Bosch dishwasher model SHX46A why does the on/off switch and lights stay on while the dw stopped running?
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
Nov 20, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
My dishwasher is not cleaning the dishes as well as it used to. Are there some simple things I can try before calling a tech?
Use a good quality powder detergent.
Check your incoming water temperature, 120 degrees plus.
Use a rinse aid such as Jet Dry.
Start the DW without soap and no dishes.
Once it starts the wash cycle pour in 1 quart of WHITE vinegar and let it finish the full wash cycle.
Then load up with dishes and powder detergent and run a load.
Jan 13, 2011 | KitchenAid Dishwashers
I have a gsd5610 and my drying button is blinking.the unit will not start
Someone opened your DW during last washing cycle. The Machine paused but no-one pushed the button to resume the cycle. It's still waiting for you to tell it to finish last cycle. Press your PAUSE/Cancel button 'til the light goes off. Then use your machine as you normally would.
Hope this info was helpful to you. Good Luck! :-)
Jan 31, 2010 | GE 24 in. GSD5930 Built-in Dishwasher
Frigidaire FDB635RBB heat wash/heat rinse
Most DW today take a minimum of 90 minutes. Run the hot water from the sink until it gets hot, then start the DW, this will shorted the first wash cycle. It is not uncommon for the DW to run 2hrs or more based upon the water temperature entering the DW and the soil level of the items in the DW.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
LG LDF6810 Drying Cycle?
This is normal and the amount of water can depend on how soon after the cycle has finished as to how much condensation is on the walls.
Jul 26, 2007 | LG 24 in. LDF 7811 Stainless Steel...
Kitchenaid dw clean light still blinking/ machine won't run...
I tried the following sequence, as recommended on a similar blog and it worked!
Open door
Quickly press :
Hi Temp Scrub
Energy Saver Dri or Heat Dri
Hi Temp Scrub
Energy Saver Dri or Heat Dry
Close door
All lights should come on
then clear and revert to cycle.
Feb 28, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
GE GSD5610D Dishwasher Logo
18 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
