GE ECM Motor Troubleshooting
Lennox 18m8101 furnace system have ecm blower motor just rock back and fouth does,nt spin how to reset let it spin
Therinnaiguy
  • 1420 Answers
SOURCE: blower motor
Hill, which blower motor? The exhaust inducer or the room air blower? If you are referring to the exhaust blower, check for a restriction in either the fresh air inlet, exhaust pipe or condensate line. If you are referring to the room air blower and you already replaced the motor, it is most likely a relay on the control board. You will need to replace the whole board. More info is always better!
Posted on Jun 13, 2008
  • 124 Answers
SOURCE: carrier 58mvp furnace ecm motor is making viberating noises
ecms are pretty reliable and electronic failure is much more common than bearing or bushing wearout. i suspect the fins on the blower may be coming loose from their pressed on spline and that will start a vibration or shimmy or you could have thrown a weight that balanced the wheel . best to use to warranty to get a new wheel. good luck
Posted on Dec 07, 2008
mastatech
  • 478 Answers
SOURCE: blower motor wont shut off
Turn the fan to the off position on the tstat. You colud have a ilimit switch or a relay on the control board if it has one.
Posted on Mar 25, 2009
inst
  • 12 Answers
SOURCE: dont waht to get ripped off by paying 1200 dollars for a 100 dollar motor
Check the following link.
http://forum.doityourself.com/air-conditioning/270140-ge-ecm-programmable-motor.html
My system failed today. I jumped the Thermistor to get me by until the replacement get here.
Total cost plus shipping was under $30.00
Posted on Jun 22, 2009
luker711
  • 91 Answers
SOURCE: ecm motor on york package unit, motor does not run
If the shaft doesn't freely spin then the bearings have seized and quite likely will not free up. Check to see if there are oil ports on the motor. If there are little plugs on the motor, make sure electric is off and then take out plugs and get a zoom spout type container of oil and put a very little bit of oil in them. Plug the ports back up, move the blade around a little. Re-energize unit and see if it starts.
Posted on Jul 10, 2009
Furnace motor fan runs to slow, whats the problem?
need to replace the motor bearings are going out of motor.
Sep 15, 2014 | GE Carrier Bryant Furnace 1/2 Hp Ecm...
Need circuit diagram for 2033001
this is a highly advanced motor with multiple inputs giving it its variable speed capability. Schematic wont help. Sorry. Motor shot or main board shot. Both expensive
Feb 10, 2014 | GE 1/2 Hp Ecm Blower Motor Hd44ae121...
Blower motor goes off
The ecm controlled motors are know for ecm failure. They do not like high speed(T5 terminal connection). Normally when the ecm is acting up the blower will not work at all. But I've seen em run for a bit then quit. The motor probably needs a new ecm
Oct 21, 2017 | Goodman Heating & Cooling
I have a Bryant hvac system, model 315aav / jav, that started making a loud buzzing noise whenever the fan is running, whether on furnace or a/c. Any ideas as to what the problem might be?
I would say that either you have a loose fan guard ,you have a contactor that is loose and not making good connection, or a motor that is getting bad. Possibly the strap holding the fan motor is loose around the motor and letting it vibrate
I would try to narrow down if it is vibration buzz or a motor or is it coming from the area where all the control parts are
Sep 13, 2013 | GE 1/2 Hp Ecm Blower Motor Hd44ae121...
Need circuit board diagram for CES0110057-2
Are you positive the motors not shot? In my opinion, that's more likely, but Im going of what I know. Why do you think its the board?
Oct 20, 2012 | GE 1/2 Hp Ecm Blower Motor Hd44ae121...
Lennox Furnace
Make sure to check and see if you do not have any bare wires touch ground or if you have any wires pinched causing a short to ground. Safety first so turn of power before checking. Also check to see if any wires on unit are touching one another. Hope this helps you.
Feb 15, 2009 | Heating & Cooling
Carrier 58mvp furnace ecm motor is making viberating noises
Dec 07, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
