Question about Ovens
Whirlpool rbd305pdb12 oven does not display anything. when I try to turn it on, it just beeps three times and nothing else. I replaced the motherboard two years ago. could it be the same thing?
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Posted on Jan 20, 2008
SOURCE: Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Posted on Jan 28, 2009
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Posted on Feb 21, 2009
espressonist
  • 1711 Answers
SOURCE: My whirlpool double oven accubake GBD307PDS09
We have here a video showing how you can check the temperature sensor
We also here the parts diagram of your model
Posted on Aug 20, 2011
Display went out on my whirlpool RBD305 oven and then it stopped working
You will need to replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Whirlpool RBD305PD Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Whirlpool RBD275PDB14 Double oven digital display board off.
Had the same problem. I repaired the board myself and ordered a replacement from sears parts direct. It is a repaired board not a new one but has the same warranty. You can get this board a lot faster. Here is the link. http://www.searspartsdirect.com/partsdirect/part-number/8302319R/0022/664. If you would like to repair your own board leave a post and I will help you.
Nov 16, 2011 | Whirlpool RBD305PD Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Aug 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Dislpay is blank but oven works
HI, you will need to replace this faulty ECC. the chip set that is soldered on this board is damaged as well as the led display. replacing the Electronic Clock Control will fix this issue.
the control board is fine and this explains why the oven is still functional. its the ECC that is faulty.
Click here to purchase your new ECC online.
May 25, 2009 | Whirlpool RBD305PD Electric Double Oven
Oct 31, 2008 | Ovens
Display is black
I had a very similar problem (I was observing the error & fault code "E6 F2", but not always.  I did always have the beeps.) on a Whirlpool RBD305PDS14 double oven built-in.  I spent time today (Oct. 21) and traced the problem down to the keypad flexible cable that connects the keypad to the oven control panel.
[ALWAYS WORK WITH POWER OFF!!!]
I cleaned the flexible cable contacts that seat into the board mounted female connector on the control panel board using a Q tip and isoproply alcohol.  This did the trick.
(Elsewhere in this forum, there is information on how to remove the oven control panel and gain access to the control assembly.  I posted this information - keywords in subject: Whirlpool RBD305PDS14.)
Sep 25, 2007 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
43 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
