Question about Amana Refrigerators
Amana asd2522wrb04 loose door handle
Please help. Door handle is loose. How do I tighten the handle?
aborcass
  • 2651 Answers
SOURCE: Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Posted on Mar 12, 2008
SOURCE: Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Posted on Mar 28, 2008
SOURCE: Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Posted on Jun 24, 2008
blueextc3221
  • 15935 Answers
SOURCE: The door handles are loose. I want to tighten them
Remove the door gasket - and you will find the handle screws.
CLICK HERE to see the diagram.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jan 13, 2010
  • 4 Answers
SOURCE: Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Posted on Jan 24, 2010
The handle on the door of my bottom freezer Amana has come off where it is attached in one of two places to the door. The handle was held in place by two screws. They have come loose and there is no way to...
Push the handle in and slide it to the side. It should come off and you can tighten the screws and re-attach the same way. I just about destroyed my door before i figured this out.
Aug 03, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
Bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
Oct 15, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
62 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
