Question about Tablets & eReaders
Cant connect to wifi on trio stealth
I have a trio stealth lite 4.3 tablet and when I enter password for wifi it keeps saying authenticating. what do I do
SOURCE: my galaxy tablet cannot detect
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
Posted on Jan 04, 2011
SOURCE: I have the Archos 101
I had the same problem with my third Archos 101 (I've had two replacements to the first one I bought in June 2011). I just got the third one two days ago and it wouldn't connect to my WiFi like the previous two would. I had to add the 101's MAC address to my router's setup and now I'm connecting to the Internet. Alternatively, if your cell phone supports tethering (my HTC Tilt does) you can tether your 101 to access the Internet through your phone. Mine is working well that way....for now.
Posted on Oct 16, 2011
jakaripage_j
SOURCE: how can I connect my tablet to wi-fi
on your settings go to wi fi settings turn it on
Posted on Apr 06, 2012
caroldon
  • 17130 Answers
SOURCE: my internet tablet keeps saying network problem when i try connecting to wifi
Please check your password and see the strength of the WI-Fi in your area. If this a wifi of your home wireless modem then check the modem and reset accordingly. switch off power for some time and restart.
If not check your tablet on another wifi to confirm this or if the configuration has gone off from the settings.
make sure that your password and the network is connected as seen on the lower taskbar .
Posted on Jun 07, 2012
  • 21 Answers
SOURCE: do i get into my tablet trio if i don't know the password or my gmail account
you can make another account and use that.you can have as many gmail accounts as you want
Posted on Mar 10, 2013
I cant sing in to gmail on my trio stealth tablet, says cant conect to server.
Log onto the network. You will need the password for the network.
Sep 03, 2017 | Tablets & eReaders
Have a Trio Stealth -10 wont connect to the WiFi
Is wifi turned on on the tablet? If not, go to Settings>Wifi and turn it on. The device should then automatically scan for networks.
If you are able to connect to your network but then cannot actually get to the Internet you may just need to restart your router. You might get something like "Obtaining IP address" for a long time and then get "Limited" connection. Correcting this may be just a matter of unplugging it for about a minute then plug it back in. Wait 4-5 minutes for the router to boot up completely then try connecting again. Some routers are sensitive to new devices. When I had AT&T Uverse router I would have to restart it every time I tried to add a new wifi device.
Hope this helps.
Jan 03, 2016 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
How do I connect to the internet
tap setting slide wi-fi to on position the device will autoscan for wifi select your wifi and enter your wifi password
Jul 05, 2015 | Mach Speed Trio Stealth G2 Tablet -...
How do I connect to bluetooth
Go to setting turn on Wifi and search in a few minutes it should show available networks connect to your network and if protected enter password from router or modem. Will will tell you if it is connected or trying.
Feb 21, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
My WiFi is up and running and my other devices can connect but my trio tablet says authentication problem, why can't I connect?
I'd make sure that you have configured the correct wireless security type. If your tablet allows both WPA and WPA2, make sure whatever you selected matches the configuration on your WiFi router. Also, the encryption algorithm has to match - AES is the most common but some older routers only support TKIP.
Feb 13, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
I have a wifi password an i can't figure out how
From the main menu select settings and then wi-fi settings. This will prompt you to connect to network and if it finds your wi-fi router it will ask for the password.
http://www.brandsmartusa.com/pdfs/manuals/20179969.pdf
Sep 24, 2014 | Tablets & eReaders
Why won't my tablet connect to my wifi ....
Once you identify your wireless network (SSID) you must put in a "password" or network key.
Jun 19, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
My trio tablet wont connect to wifi. It says Authentication Problem.
hi,
1.this happens if the SSID or Network name is the same in two places that you go to, but the password is not the same
2. it could be your router that needs resetting, or just unplug and plug it back up and see what happens
3. you can Delete - or tell your tablet "forget" the network in question and reconnect all new
4. if non of the above works - turn your device off and wait a little bit and turn it back on
let us know if this help
thanks
Oct 18, 2013 | Machspeed Trio DROID-7C Tablet
Tablets & eReaders Logo
223 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
