Question about Dewalt Saws
Dewalt trigger switch wiring diagram - Dewalt Saws
  • 313 Answers
SOURCE: Switch diagram
as u notice the terminal on the switch has 2 connection like a switch diagram to it.it has normally open & normally close contact. the normally close contact are for red & white wire & the other
contact are for 2 black wire which is normally open contact.hope it helps.
Posted on Sep 19, 2008
rowdy45176
  • 2176 Answers
SOURCE: DW272 switch wiring
I would go to the mfr's website and download or look at the wiring breakdown. All these companies have breakdowns online
Posted on Dec 16, 2008
  • 25 Answers
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Posted on Apr 18, 2009
SOURCE: Replacing a power cord for a Dewalt electric drill
some of the dewalt drill switches have a one way trap (like) for the wire. you push the wire in and the harder you pull it gets tight on its self. your wires go in the bottom of the trigger look right on top of each wire there is a small **** (no bigger then 3/16) for a flat head screw drive. In the **** you will see a small lever, it needs to be turned at the same time pull. It will help to have a friend.
Posted on May 27, 2009
smjdragonfly
  • 79 Answers
SOURCE: How to wire switch for Dewalt DW718 Type 1 mitre saw.
Does the switch not have color words on the back of it? They used to. Go to Dewaltservicenet.com and look up your model number and type number. Wiring diagrams will be found there. Lemme know. Please rate me
Posted on Jun 18, 2009
The 3 led lights wont go out on my brushless dewalt impact driver after ive pulled the trigger??
faulty trigger switch suggest to clean the inner part of switch or insulate seized wire or renew faulty trigger stitch
Aug 03, 2017 | Dewalt Drills
I have a dewalt DW712 8.5" slide saw. My trigger came apart, i need to know how to reassemble the trigger? " where do the springs go" for instance?
The spring is positioned so as to provide a constant pressure on the switch so when it is depressed the switch will close the electrical circuit. If you go to the DeWalt home page and query the model for a repair diagram will also assist. You will need some back ground in assembly and mechanical drafting.
May 20, 2014 | Saws
Wiring diagram for dewalt hammer drill trigger
Go to www.2helpu.com it's their help site.
Mar 31, 2013 | Dewalt Drills
When i put air to my gun it has rapid fire and will not stop. How do i fix this
It sounds like either the trigger valve is stuck of malfunctioning. It is item 68 on this diagram. With the toll UNPLUGGED from air make sure the trigger pin is releasing as it should when the trigger is depressed. Obviously do not check this with it plugged into an air line.
DeWalt D51823 diagram
Aug 06, 2012 | Dewalt Tools & Hardware - Others
D25600 does nothing when i pull the trigger
take it to a repair shop.could be broken wire in lead,could be burnt out armature,could be crook trigger switch,try a new plug on the lead
Jul 05, 2010 | Dewalt D25600K Electric Rotary Hammer
Dewalt power saw wiring diagram for trigger switch dw-708 type 4 wire colors to swith positions.
Y---o o---R
B---o o---B
Apr 12, 2009 | Dewalt Saws
Need wiring diagram for dw505-2 trigger
Here is your parts diagram just in case you need it.
http://www.ereplacementparts.com/dewalt-dw505-type-hammer-drill-parts-c-1009_9661_2281.html
And here is the number to a factor tech which could answer your question on trigger wiring. There is no diagram available but, I'm sure a tech will get you up and going.
(702)889-6025 ask to speak to a tech.
Mar 31, 2009 | Black & Decker Dewalt No.DW505 Heavy Duty...
Saws Logo
71 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
