Question about Dryers
Hawaiian breeze fan Hawaiian Breeze 12" Retro Table Fan, Oil Rubbed Bronze, FT30-9U3 the knob came off, the pin seems to have a spring and I am unable to put the knob on Do I need take it apart ??
4 Suggested Answers
  • 6771 Answers
SOURCE: My Hawaiian breeze floor fan just stopped working
One of the most common problems is the switch, bad ac cord, an open winding in the fan motor. The on/off switch and ac cord should be checked first, now! if the motor is humming but not working it is seized, the bearing is burnt, or scorched, and possibly cracked.
Posted on Mar 21, 2011
  • 8 Answers
SOURCE: How do I clean a
All Equipments has a provisions for servicing even for cleaning only.
Posted on Jun 19, 2011
SOURCE: How do I clean a Hawaiian Breeze tower fan?
Unplug fan. Lay the fan face down. Remove the four screws holding the stand to the base. Slide the stand all the way off the cord. Look at bottom of fan and find the small half circle indent just to left of center. There is a screw there, remove it. Go to the hand grip at the top of the back and pry out the two white rubber plugs to reveal two more screws, remove them. Back cover can now slide downward. May take a little squeezing at the center of the grille where internal clip is. Remove two screws at top of squirrel cage. Turn squirrel cage and loosen screw at bottom collar on motor shaft. Tilt the top of the squirrel cage outward slightly and slide upward to remove the squirrel cage. You can slip upper metal bracket off and set aside. Motor is held in by two screws, remove them and flip motor out of the way. There are two screws below where motor sat that hold in base of front grille, remove. Front grille has a series of clips along edges, carefully pry them inward from bottom to top and push grille gently outwards. You can now clean the rear grille, front grille and squirrel cage in warm soapy water and allow to dry. While they are drying, use a vacuum and dust rags to clean interior. When parts are dry, reinstall front grille and reinstall 2 screws. Reinstall motor with two screws. Turn motor shaft so flat notch is pointing up. Recommend to spray a tiny bit of WD-40 or a tiny dab of moly grease on shaft at top of squirrel cage, then replace upper bearing bracket on top shaft. Slide collar end of squirrel cage onto motor shaft and align screw with shaft flat and tighten. Reinstall two screws at bracket at top of squirrel cage. Align back cover just a bit toward bottom, then slide upward and clips will snap into place. Reinstall two screws in hand hold area, then reinstall screw at bottom of cover at half circle notch. You'll need either a magnetic tip screwdriver or a pair of long needle-nosed pliers to get screw in hole before tightening. Feed cord back through base and reinstall 4 screws. It took me about half an hour to do this whole process on each of my two Hawaiian Breeze fans, but they now look brand new and run very quiet.
Posted on Jul 04, 2011
Where can I find replacement mister nozzles for a Hawaiian Breeze misting fan
They are not available Debbie. What is wrong with the ones in yours? If they are clogged you can clean them with CLR or white vinegar. Or set up a patio misting nozzle in front of it.
Patio misting nozzles are readily available. Your fan is discontinued.
http://www.bing.com/search?q=+Hawaiian+Breeze+misting+fan+nozzles&qs=n&form=QBRE&pq=hawaiian+breeze+misting+fan&sc=0-27&sp=-1&sk=&cvid=EBB007E7ED6D49A6BD8E6A22CCCC31E0
Jul 09, 2016 | Dryers
I have a Hawaiian breeze floor fan no.FE45-B2 and it just stopped running. Does it have a fuse and if so what is it? Unable to get into controls with ... Odd triangle screws?
I doubt that it does. Most fans these days are not meant to be repaired. Try a different outlet and try different speed settings.
Jul 03, 2016 | Dryers
I have Hawaiian breeze fan. What is the longest amount of hours its safe to keep on. Can I leave on while at work to keep my cats cool? Thank you.
Yes. You can run it all day long. The only thing you have to worry about is that the fan is in a secure place where it cannot be tipped over by the cats if they bump or jump into it.
Jun 03, 2014 | Dryers
My Hawaiian breeze stand fan will randomly change speeds without being switched Why is it doing this
If you have a remote, just change the frequency in the receiver & transmitter.
Feb 23, 2014 | Dryers
Guards won't stay facing down?
DEAR SIR, PLZ TEL US.HOW TO INSTAL/FIX THERMAL PROTECTER IN CEILING FAN.AND IT FUNCTION.WHY IT MUST FOR CEILING FAN.WHERE NEED FROM MARKET.ITS FUNCTION DETAIL.WHEN HE WORK PROPERLY IN CEILING FAN. alahamadfan@yahoo.com malik jameel awan.
Jun 17, 2013 | Dryers
My hawaiian breeze 16" fan isn't working properly.
try wedging a paper clip in between to hold the gaurd in place.
Jun 17, 2013 | Cars & Trucks
Jun 18, 2011 | Tower Aloha Breeze Fan
My Hawaiian breeze floor fan just stopped working for no reason? Any solutions
Mar 21, 2011 | Dryers
Aug 05, 2010 | Tower Aloha Breeze Fan
Dryers Logo
Top Dryers Experts
