Question about Canon PowerShot A95 Digital Camera
A95 Start Problem
Hi and thank you, my A95 just stop working well a few days ago, when I press the on/off botton it flash one time and then nothing, this is in playback mode, in shoting mode, it tries to open the lens but don´t do it completly, one time did it, I even took a picture and then stop working, I had change batteries, CF, review the pins of the CF, and the battery and CF covers, nothing. I had read about the CCD problem, but I am not sure if that is my case? It is out of warrranty and I am not even in the us,in my country there isn´t a canon service for digital cameras, so I really need some help.
  • osced Aug 30, 2007
    I am sorry I forget to mention that the CCD doesn´t flash or start, it´s completly dead. Any suggestion would be helpful.
    thank you
  • paes Feb 20, 2008
    my cam powershot A95 lcd is blurry everytime i open it... then the when shoot the output have on lines on it... WHAT MIGHT BE THE PROBLEM?
  • 30 Answers
I'd suspect a broken ribbon cable connector latch where the keypad matrix ribbon connects to the main board.
Posted on Feb 01, 2008
6ya staff
SOURCE:
Power botton flash and no start
check your ram.......via system info...
Jan 29, 2014 | Acer TravelMate 4000 Notebook
Had my toshiba regza 42rv530u since March 2009 a few days ago it cut off and will not come back on, the yellow light flashes at the bottom of the tv, 3 blinks pause 3 blinks etc....
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
May 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
My 91 gmc vandura 3500 skipping/stalling/bogging
It clearly sound as though your timing chain is stretched and should be replaced soon. Thanks' Dana
Sep 30, 2009 | 1991 GMC G3500
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Oct 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Delay Between Flash and Taking Photo
I also have this problem on a Canon A85. For some reason setting the camera to landscape allows the shutter and flash to work together properly.
Aug 24, 2008 | Canon PowerShot A95 Digital Camera
Canon A95 - Download freeze after several pics
Reset the camera settings back to default.. thats all it will be alright!
Mar 19, 2008 | Canon PowerShot A95 Digital Camera
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Canon PowerShot A95 Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
