Question about Kitchen Ranges
Simpson gemini atlas thermowave series
How to set oven to work manually buttons pressed in error when cleaning
SOURCE: Simpson Atlas Apollo ceramic top
Hello, I think I have the same oven as you, and yes the oven doesn't seem to work unless the clock has been set.
On my oven, there are 4 buttons and a dial below the digital clock.
To set the clock, you need to turn the dial whilst holding any two of the 4 buttons down.
For me it's a two handed job.
Cheers,
Michael
Posted on Dec 07, 2008
tina_tait
SOURCE: bottom element not working tried a new element still not working
I THOUGHT THE INFORMATION WAS TOO STEEP I WILL WORK IT OUT MYSELF
Posted on Jun 22, 2009
  • 382 Answers
SOURCE: I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Posted on Dec 22, 2009
  • 17 Answers
SOURCE: turned wall switchoff to clean
hi, on most ovens, if you switch the ovens power off the oven won't operate until you have set the time on the clock. Try setting the time and see how that goes.
Posted on Mar 22, 2011
SOURCE: auto cooking
all i want to no is how to activate the oven when the power comes back on which nobs to press
Posted on May 12, 2011
I'm having trouble setting the oven to manual-pressing the cook time and the ready time simultaeously no longer seems to work
It could be that the contacts need some cleaning. Turn the power off and then repeatidly press the buttons. This action may will clean the contacts. If this doesn't work then a new timer from espares is about £80.
Nov 17, 2010 | Stoves 720EF Electric Double Oven
I need to clean my double ovens, but do not have the owner's manual. I know that I simple press the Clean button, but how long do I set the timer for?
You only need to reset the time if you want a cleaning cycle other than 4 hours. The default start is press Self-Clean then Start. Otherwise, press Start, type in a time between 3 and 5 hours (Min/Max cycle length) and then press Start. Do this with the number pad, do not press the Timer button. If you wish to clean both ovens, the second one will start when the first one finishes.
The Locked door light will go off when the oven has cooled below the Lock temperature. If you interupt the cleaning cycle by pressing Clear/Off, the door will remain locked until the oven cools.
I hope this helps.
Sep 25, 2010 | GE Profile JTP56 Electric Double Oven
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
What does the error code F1 indicate, on a Wolf Oven?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 24, 2009 | Ovens
GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps! RC
Jun 21, 2008 | Crosley CE35111AA Electric Kitchen Range
Error Code F1:E3
reprogram the control board as following:press buttons on range
power off wait 5 sec
power on wait 5 sec
convection broil
clean
backed goods
stop time
190
timer set
start button 12 times(it will go through all the settings)
Mar 17, 2008 | KitchenAid KESC307 Electric Kitchen Range
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
