Service manual 39l1350u toshiba led
Mod 39l1350u. Sku 8130199
Tv has issue on the start up then if toshiba sign does come up the tv works maybe for 2hrs then whole screen becomes straight up and down colour lines
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 25, 2015 | Toshiba 39L1350U 39" LED TV 1920x1080, 120...
What parts to fix a blank screen besides power supply and main boards (have tried both)?
STOP Get a SERVICE MANUAL and follow instructions before you make it any worse by "Mucking around with it" it needs to be serviced in a set careful methodical way u cant just replace boards and hope as those boards may damage or be damaged, to have any chance u need to get the book plain and simple less expensive too.
Aug 21, 2015 | Toshiba 39L1350U 39" LED TV 1920x1080, 120...
What part number is the "T'Conn board" for a Toshiba 39L1350U LED TV? I was told this is the part that needs to be replaced.
Its number will be printed on it. There are many types of it fitted with same model sets; so it can't be predictable. Will depend on what type kit are used. Look for it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 20, 2015 | Toshiba 39L1350U 39" LED TV 1920x1080, 120...
How do I repair my Toshiba LED TV?
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 17, 2015 | Toshiba 39L1350U 39" LED TV 1920x1080, 120...
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
SERVICE MODE TV LCD TOSHIBA 19HV15E
1/3 layar ada garis2 vertikal,apanya yg rusak
Apr 19, 2013 | Toshiba 19HV15 19" Multi System LED TV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
