Question about Saws
Change central machinery band saw blade - Saws
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
clyde2j2
  • 137 Answers
SOURCE: help with my dw100 band saw
Pull the plug on the saw, take off the covers on the upper and lower wheels of the saw.
You will see an adjustment bolt above the upper wheel and below the lower wheel, with the band saw in place on both wheels turn the upper wheel by hand, if the band saw moves to either side of the wheel use the adjustment bolts to center the band saw.
Posted on Jan 30, 2009
  • 360 Answers
SOURCE: band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Posted on Mar 31, 2009
Editor925
  • 285 Answers
SOURCE: band saw ,blade length
The blade length used on the 9422 is 52.75 inches.
Please rate this solution on FixYa!
Posted on Apr 18, 2009
Where can I find a replacement blade for a central machinery meat saw with a 76 3/4" blade
harbor freight has there own parts department , they sell parts for everything they sell , I just got new brushes for my electric drill from them , give them a call !!! ask for parts !!
Apr 09, 2016 | Blade Saws
Screeches when I cut wood
open the front and watch it when you turn on sounds like you have a piece of wood stuck somewhere
Apr 01, 2015 | Central Machinery 9" Bench Top Band Saw
I need the blade guide assembly for a Central Machinery 14'' band saw,where would I find this part?
Go visit carter products' website. They have what you need for your band saw.
Jul 09, 2014 | Saws
Need manual for 9" band saw
I think the HF 9 inch band saw is just the same with your machine. Try to contact them thru email to request a manual. Try to check bandsawmanuals.com , they have many free downloadable manuals on their site.
Jan 23, 2014 | Central Machinery 9" Bench Top Band Saw
How to replace blade for central machinery Model t-1582
This saw has been discontinued by Harbor Freight. However, you may able to ask from them a manual by sending them an email. Try to check this manual. Hope that helps.
Nov 24, 2013 | Saws
Looking for a manuel for my central machinery meat saw cant find one
If Central Machinery can't supply a manual or information on where to get one, you may be out of luck
Oct 10, 2013 | Saws
Replacement parts for central machinery bandsaw, blade and belt
take a look on amazon: Amazon com bandsaw blade, Last time I bought same parts from there. cheers
Dec 31, 2011 | Saws
Saws Logo
77 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
