Sharp mx 5001n
Printer won't turn on. power save keeps flashing. pressed on button and the screen won't turn on. how do i turn machine on?
  • 54 Answers
SOURCE: Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Posted on Jan 01, 2008
SOURCE: epson stylus d92 printer
I think that this "error"is due to an internal copy counter.
I have a Epson Stylus D68PE, and had the same problem.
I performed a research for a file to reset the internal counter, and I found a file "C67C68D68" that is an "EPSON ADJUSTEMENT PROGRAM", with different softwares for each type of printer.
after launch the program, and reset the counter, the printe work OK.
This counter is as similar as the counter of the laser copiers.
As you reset the chip on ink tank, after a specific numbers of print, you must reset the internal counter. By yourself, of by MAINTENANCE (very expensive) Good luck.
Posted on Sep 24, 2008
  • 121 Answers
SOURCE: Paper feed button flashing
Check your user manual for resetting the printer to factory default settings.
If that doesn't work, unplug your printer from the computer and uninstall your software through Add/Remove Hardware. Shut down your computer and reboot. Reinstall your printer software, following the instructions carefully.
This should clear up your problem.
Let me know if you still are having problems. :)
Posted on Oct 08, 2009
  • 73 Answers
SOURCE: Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Posted on Dec 07, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: I have a Sharp AL-2020 All in One printer. The
To reset the drum light on your Sharp AL2020 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the "auto" key (exposure mode) then the "C" key then the "auto" key again.
So in other words C, Auto, C, Auto
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Dec 20, 2010
Printer sharp MX-B402SC It was working fine until when i turn the printer off by unplug the power cable and When i turn the power on later machine worked but the screen is Black so i can't make copy
Is there a little green light on in the furthest top right hand corner of the front keyboard? Also, is the standby button below the light in the up position? If so press it down, this is why the display is black.
Hope this helps.
Dave.
Dec 01, 2016 | Sharp Mx-B402sc mx-B402sc
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
Hi I have a sharp mx 3500n and I left it on and went out for an hour , when I come home it was in powersave mode but I couldn't get it to turn on. so I turned everything of and then it reboote
There is a hidden power switch that might have gotten turned off...it's under the front cover where the toner is in the bottom left hand corner. If that is off nothing will power on. If that it on and it still won't work the power supply probably needs to be replaced, which will be an expensive repair.
Copier Collin Houston TX Copier and Imaging Expert
Oct 29, 2014 | Sharp MX-3500N Laser Multifunction Printer...
Selected servers not found
This is a common error when using Sharpdesk and the Network Scanner tool. Take a look at my cheat sheet on how to fix this problem.
Sharp Scanner CE 02 Cannot Connect to Server Consult your Network...
Aug 26, 2013 | Sharp MX-5001N Copier - 50 PPM Full-Color...
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
WE NEED TO CHANGE THE DEVELOPER IN OUR SHARP MX 5001N COLOR COPIER
The developer change is quite easy, have you ever done anything like this before?
Is it just black or colours as well?
Jul 12, 2011 | Sharp Office Equipment & Supplies
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
How do i clearn a maintenance code fk3 from a sharp 5001n
this is a web cleaner replacement which is cleared with p/# * c * then 2 4 copy start 4 copy start. press web cleaner button and execute. Note if the web cleaning web has run out (probably has) it will need to be replaced. machine can run without this for a while but the fuser could start leaving dirty marks.
Oct 14, 2010 | Sharp Office Equipment & Supplies
Sharp MX-2300N with error code H3-00. . how do I fix it?
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Mar 09, 2010 | Sharp MX-2300N Color Copier
My new Sharp MX-5001N printer has duplex capabilities and I have been able to accomplish this through MS Word, but the document I'm merging now is Corel WordPerfect 12 and with everything set that should...
Create them in Word perfect, but see if ms word will open them. You can likely get word to print them. You can also try the collate feature of the printer in the printer settings.
Oct 20, 2009 | Computers & Internet
63 people viewed this question
k24674
