Question about Singer 3323S Talent Sewing Machine
Singer talent 3323s how to set timing
Needle will not move up and down
louislevel_2
  • 374 Answers
SOURCE: Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Posted on Apr 03, 2009
  • 980 Answers
SOURCE: singer machine problem
First thing to do is take out the bobbin and bobbin case, there may be a small piece of thread jammed holding the machine back, if it is still tight after that oil with WD40 on all moving parts, if that fails it will be a shop job.
Posted on Oct 18, 2009
  • 5603 Answers
SOURCE: singer 427 cannot move needle
The machine timing has gotten out of adjustment. Slipping of an adjustment is causing the needle and shuttle to interfere. If the shuttle around the bobbin is not rotating, something has come loose. If you open and manually rotate the works you should be able to see what is not moving that should be. It may have lost a pin from a shaft or a setscrew. Test this without the needle in place.
Youtube has some good videos for the repair of the problem. Search for "sewing machine timing"
Here is one: http://www.youtube.com/watch?v=2OjjqmFAFLo
Posted on Jan 04, 2011
SOURCE: I have the singer model 337 and the needle is down
is the machine a drop in bobbin or front or side bobbin?
Posted on Mar 22, 2012
SOURCE: My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Posted on Apr 16, 2012
I have a singer 3321 talent. Where the bobbin sits is catching & clumping, creating a birdsnest on the back. I tried rethreading both the bobbin and the top, checked my needle, adjusted the tension.
If you haven't already, install a brand new needle. Then make sure to RAISE the presser foot before threading the upper thread.
Also check to make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues, then it probably needs service.
Mar 13, 2016 | Singer Sewing Machines
Motor is running but the needle doesn't move up and down..
gears not engaging. It should have a peddle for the foot from what I remember. Bad switch
Just a guess to be honest because both hands should be needed to move the cloths
Sep 28, 2015 | Singer 3321 Talent Sewing Machine
Need instructions for Singer side cutter model CY9000L. I have a Singer Talent 3323
http://www.amazon.com/SINGER-Attachment-Low-Shank-Sewing-Machines/dp/B00G6TW7ZK
There is a video tutorial on this Amazon page on how to use this attachment. Basically,, the forked arm fits over the needle clamp, and it attaches to the machine the same way any presser foot does. Check the video, it's very clear. The video is the last one of the group of small picture icons on the far left side of the page near the top of the page.
Oct 09, 2014 | Singer Side Cutter Attachment Presser Foot...
Singer bobbin thread not being caught
try rethreading the machine top & bobbin
change the needle--flat side to the back of the machine, make sure the needle is the right one for the fabric being sewed
clean under the needle plate & in the bobbin area for lint or theads
May 10, 2012 | Singer 3323S Sewing Machine
Singer sewing machine Manual Model 3323S
Hi Connie,
Thanks for choosing Fixya.Sorry about the tumor.
Here's the manual free of charge!
Hope this helps.Thanks!
Dec 18, 2011 | Sewing Machines
h! there,
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
Mar 15, 2009 | Singer 5050 Mechanical Sewing Machine
Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Jan 19, 2009 | Singer 3116 Simple
Singer 3323S Talent Sewing Machine Logo
67 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
