Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Booting problem(When I ON my pc its not booting but shows only desktop board )
,when I boot my computer system it immedietely shows the intel inside logo and doesnt boot,when I check BIOS it will not detect my HDD ,It only show floppy drive and Cdrom drive in boot priority but trying many times to on /off System its start Botting my system. I tried to repair it by changing IDE cable from CdROM to HDD and re fitted tightly all Connection along with RAM but itwill not give any positive effect. Please tell me about the solution of my problem so that I can get rid of it. I am using pentium 4 with intel desktop board D865GBF having 3.0 GHz processor, Win XP-2 OS with IE-6
  • Jalal Ahmad Sep 02, 2007
    As I do not have another Machine, this solution was not possible for me to check. I have check mu HDD by the utility software provided by Samsung.It shows there is no error in my HDD.Any way I plan to find another HDD and check on my system for the problem.
Have you tried the HD in another Machine? The HD could be at fault.
Posted on Aug 30, 2007
My hp desktop says internal hard disk not found how do i reset my drive
First reset the CMOS. Check your motherboard specs for how to do this or remove the small round silver battery from the motherboard; wait 30 seconds and reinstall it. (It is a good idea to replace with a new battery.) This will reset the CMOS. Then reboot to see if HDD is detected. If not, go into the BIOS setup (repeatedly hit F10 at HP logo screen) and check to see if your hard drive is listed. You may have to set it to "on". If it is listed in BIOS, but not detected another drive (a bad one) could prevent it from being detected. If you have any removable or external drives attached to your computer, disconnect them. Reboot your computer to see if your HDD is detected. If not, open your case and disconnect the data cable from all drives except your primary hard drive. This includes the floppy, optical, zip, backup, or secondary hard drive(s). If your HDD is detected, reconnect each drives data cable one at a time rebooting between each. If after reconnecting a drive and rebooting, your HDD is not detected the last drive is a bad drive and preventing your HDD detection. I have found that sometimes a bad drive that is connected will let the HDD be detected then on later boots the HDD will not be detected. Also it is possible that your BIOS is corrupted. Let's hope not. Another possibility is a bad motherboard. I hope this helps you.
Aug 11, 2012 | HP Computers & Internet
When compuetr starts no boot device available but BIOS seen
If there is no HDD or any other boot device the BIOS will always be present. This problem occurs if you haven't installed any Operating System on the HDD. So when the computer is booting it finds no booting device files and that's why showing error message. Format your HDD and install OS to boot smoothly. But if you have HDD with OS still this error happening then it might be a reason of corrupt system files which are required during booting or it may be the case that your HDD is damaged and cannot boot from there. If your HDD is damaged and still showing on the BIOS it may happen because it is detecting as a device but the as the device is damaged is cannot boot from it. Check these steps to solve your issue.
Jun 21, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
It doesnt show in my computer
Start your computer in BIOS and check if the HDD is detected over there. If no then you need to run a SMART test on the HDD or you need to reinstall the O/s. If the HDD is not detected then you need to reseat the HDD SATA/IDE cable after opening the cabinet. Check again in BIOS if the issue is not resolved then the HDD has gone bad.
Regards,
Shrey
Sep 12, 2009 | Computers & Internet
Bios setup cannot detected 500gb sata Maxtor
hy on your maxtor hdd you have a jumper configuration you have to put your jumper in the good configuration so your primaries hdd is the one that have the exploitation system and the other one you need to set it to secondary hdd
bye and good lock
Mar 06, 2009 | Maxtor Hard Drive
Unable to login in my computer
try setting your bios to defaults when you get in that bios screen.make sure to save it and then exit.you may also need to reinstall windows os .vista or xp etc.
Mar 04, 2009 | HP Hewlett Packard Smart Buy- dc5750...
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
