Question about Frigidaire Gallery FGHB2844LF 27.8 cu. ft. French Door Refrigerator with 4 SpillSafe Sliding Glass Shelves, 2 Clear Full-Width Humidity Crispers, External Ice/Water Dispenser, Ramp-Up Lighting and Self-Closing Pull-Out Freezer Drawer: Stainless Steel
Dispenser will not operate.
My first inclination was to replace was to replace the dispenser module, but changed my mind when it worked a couple of times. It stopped working again and I removed the module. What is strange about it is, Once I move the display just enough to get my hands in there, If I hit the push in the chute and pull back on the solenoid at the same time, it works every time. Very seldom can you catch it to work on its own. This problem is driving me Bonkers. Is this a control board issue...?
duby1990
  • 370 Answers
SOURCE: Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Posted on Nov 19, 2008
diths_kri
  • 67 Answers
SOURCE: Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle
Posted on Jan 07, 2009
diths_kri
  • 67 Answers
SOURCE: Freezer comes off and on.
try leaving it uplugged for at least 6 hours
  • 358 Answers
SOURCE: No water to ice maker. Water dispenser works fine.
The dual water valve is not working or is leaking and water freezes up in the ice maker filling tube and when it needs water won't go through.
Posted on Aug 14, 2009
Testimonial: "Good advice. It turns out the dual water valve was faulty. Thanks! "
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Comes on kicks off no freezing
    Hi Clifton - Make sure you have cleaned the unit's coils and behind the toe grille at the bottom/front of the unit. If the unit is not cooling, check to see if you hear or feel the compressor running. If you do not, contact a service professional immediately. If you do, and it is not cooling you may have a coolant leak or an issue with the internal sealed system of the unit and need a professional still. Try to clean it first however and make sure no vent on the inside of the unit is blocked by food items.
    Posted on Sep 21, 2012
    How Can i fix my dispenser that is not powering up even when plugged in the outlet?
    Get rid of it and instead install a filter system ( double or reverse osmosis) under the counter.
    Nov 18, 2014 | Avanti WD29EC Water Dispenser - Tabletop...
    FGHB2844LF water dispenser not working
    Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
    Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
    After changing the water filter, the ice maker is not working. The water dispenser is working properly.
    You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
    Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
    Sea Breeze
    Testing the Water Control Valve
    Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
    ED5GTQXKQ01 Whirlpool Side by Side motor not turning.
    This is a complicated system to diagnose, and one not recommended by the average DIYer. I would recommend in this case to have a qualified whirlpool technician at least inspect and give you a diagnosis. Due to its complicated nature, and the difficulty in accessing all the parts needed to test, if done incorrectly, you could further damage the door, or the dispenser module.
    Mar 29, 2010 | Freezers
    LG LRSC26923TT, water dispenser not working
    I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
    Sep 15, 2009 | Freezers
    Ice dispenser
    Thanks for your question!
    I'm sorry that you haven't received an answer yet.
    The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
    1. the question is unclear, incomplete, or poorly worded...
    2. the question is mis-categorized - so the correct experts aren't viewing it...
    3. the question requires an answer for something that cannot be explained online adequately...
    4. specific training, tools, or equipment are required to avoid injury or death...
    5. the Experts that are online simply don't have the resources to answer your question fully...
    Please feel free to re-work your question if you feel one of these may be the reason.
    Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
    Normal rates for FixYa are...
    $ 9.99 answer for one question.
    $12.99 Live Real-Time online chat or premium e-mail support.
    $29.99 Live Real Time phone support
    Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
    Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
    Your problem solved - guaranteed! Or your money back!!
    If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
    Jun 26, 2009 | GE Freezers
    GE Profile side by side refrigerator-freezer PSC23SGNABS
    Hi sckk,
    ngafm at your service,
    Your indoor ice and water keeps getting iced up.
    There is an air leak somewhere between the ice and water dispenser on the door and the freezer!
    there are many places that this may be. But usually the spring loaded door where the ice drops out to the door ice machine!
    It takes a good tech sometimes a couple visits changing a couple of parts till he gets it.
    There is no sure fire way to diagnose which part is the culprit thats leaking air.You need an experienced tech that eyeballs it and knows what parts to choose first to be replaced.
    The air leak almost microscopic to the eye.
    Sometimes you take ice from the door and the crack only closes full some time after wards. Then the tech comes the next day and sees nothing. Or it is intermittent problem!
    My advice is only a trained tech can remedy this problem, this time!
    If I were there I'm sure I could nail it down!
    You need hands on service!
    Bless You ,
    ngafm,
    please give me a goo rating before you sign off.
    Thank you.
    Sep 09, 2008 | Freezers
    Whirlpool american fridge freezer
    Hi, this problem IS caused by components that have failed in the rear module! Fact!
    There are a few people that sell the kits to repair them on a big auction site.
    Hope this helps
    bb
    Aug 30, 2008 | Freezers
    Frigidaire Gallery FGHB2844LF 27.8 cu. ft. French Door Refrigerator with 4 SpillSafe Sliding Glass Shelves, 2 Clear Full-Width Humidity Crispers, External Ice/Water Dispenser, Ramp-Up Lighting and Self-Closing Pull-Out Freezer Drawer: Stainless Steel Logo
    77 people viewed this question
    Top Frigidaire Freezers Experts
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    Dan Webster
    Dan Webster
    Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
