Aireze evaporative cooler manual
V Belt Size
What size room can a Hampton Bay HB 30 window evaporative cooler cool
I checked the owners manual and can find nothing about what area this cooler will service, however based on the size I doubt it will have any trouble with a small room like this.
May 20, 2016 | Hampton Bay Heating & Cooling
Can i reduce the duct vent size
yes of course you can but if its because your getting to much air you can reduce the fan speed by just replacing the pulley or if it doesnt have a belt drive system it would be cheaper and easier just to install an inverter speed control
Mar 16, 2014 | Mastercool 67471 Evaporative Cooler Air...
Cooler don't keep temperatur at 36 to 38 evaporator frozzted
Your model number on the body of the freezer will have that. You can also get size of comp. and fan and rotation located on the pieces itself.
Feb 13, 2013 | Traulsen ARI332LP-FHS 208 - 3-Section...
It starts running and after about 15 seconds it shuts down with a message of service then what i see as an alarm 7 and shuts down
If it is a evaporative cooler that is breezair, coolair or braemar it will be because it has to low or too high a voltage supply. another problem could be the capacitor is the wrong size
Feb 09, 2011 | Mastercool 67680 Evaporative Cooler Air...
I need an owners manual for my master cool. Can you help. Also, what size motor pulley is required for a 3/4 horse motor and a 1 horse motor?
Hello You need the SHAFT diamater size on the motor.And they have an ADJUSTABLE pulley to set.Bring the old one if possible.
Sep 15, 2010 | Mastercool 67680 Evaporative Cooler Air...
I believe I need to replace the motor. My cooler started making a loud noise and then just shut off and now it won't turn on at all. I'm new to this and have to do it myself but I'm having trouble finding...
Hi!!
DISCONNECT POWER TO UNIT BEFORE SERVICING.
There is not much to it, to access the belt/motor, remove side panels, loosen motor base bolts and push motor inwards to relieve pressure on belt. (you have to do this even if the belt broke off in order to install the new one), remove old belt and install new one. Slide/Pull back to tense belt. Proper tension is achieved when push belt with your finger between pulleys and the deflection is about 1/2"
Good Luck!!! Don't forget to rate this post!!!
Aug 15, 2010 | Mastercool 67680 Evaporative Cooler Air...
The fan is not working proficiency and cuts out some times
Good morning, Its kind of funny, I am off to make repairs on a evaporator cooler this day. There is not a lot to these coolers, a motor, belt drive, water pump, and a large blower wheel. You say it does not seem to be as profiicinent as it used to be, and it cuts out sometimes, or does it cut off? The 1st thing to check on these coolers, is the V-Belt.They tend to wear out quickly and will cause the motor to run much slower then normal. In stead of calling anyone out we can solve this together.If you can get to the unit If is on the roof, in a window or where ever it is, there should be a way to shut off the power at the unit or you can use the switch as long as no one comes along and turns it on if you are working on it.But, look at the belt to see how loose it is and if it has cracks on the inside all around.They should be changed twice a year. To take the belt off set by step is to grasp it with your best hand and look at the large pulley.Apply pressure to the belt to the inside of it as you turn the large pulley away from you, the belt will come right off. It is much better to let it come off at the large one 1st, then it just falls right off. On the belt, you will find a number with a couple of letter on it the belt size, such as 4L370, or A-36, and so on. Take it to an appliance parts store to get one or even a auto parts place may be able to match up the size. When you put this back on, put it around the motor pulley 1st and on top of the larger pulley. You will notice it is tighter now but that's normal. With the belt starting to go on, turn the large pully with pressure on belt and it will go on. It will be harder to install as it is new. This will solve the problem. You will notice it will move more air and run faster. There will be a bid difference. Let me know how it goes, Sincerely,
Shastalaker7
PS To get inside to do this is to take a panel one of 4 and you should be able to lift or slide it up and out.Look it over to see.
Nov 20, 2009 | Mastercool 67471 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
Bought open box product didnt come with owners manual. Just wondering what the evaporate option does on it. Does it make it blow colder air or no
The evaporator button turns on what is similar to a conveyor belt on the back of the unit. The two rollers, one at the bottom of the tank and the other is above the blower, is just like a conveyor belt, but instead of a black belt it's a white absorbent cloth. When turned on the rollers start moving the white cloth in a rotation into the tank at the bottom that is filled with water and two ice packs (you get 4 w/ it) and I put in a tray of ice cubes at night. . As it goes down into the tank it absorbs cold water and as it goes up the blower is drawing in cold liquid molecules from the white cloth, then the cold liquid molecules are drawn through the blower and out the front of the unit. This conveyor system does remove so you can remove the tank to add or change the water. This is also a filter on the back. When the Evaporator is off the conveyor just is not on. I hope I made any sense, lol. I am not a technical writer and spent 15 mins trying to explain it. I hope I helped.
I just purchased one at WalMart. I realllly like it. I have a room w/ no windows. One little air conditioner at the end of the apartment so I get none of the cold air. I heard about this so I got it. I love it! At night I don't have to have all these fans that stiffen my neck and makes it sound like I am in a airplanes turbine. Just this baby with two frozen packs at a time. I put a tray of ice cubes also at night. You do not feel water on you but it's definetly much cooler then a fan. Especially in humid conditions. People who say it sucks or does not work. They probably expected to get a stand alone air conditioner for $80 instead of $300.
The customer service # that came w/ mine is 866-876-4332 9-5 cst M-F or MideaUSA@aol.com
Apr 27, 2009 | Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
