Question about Exercise & Fitness
"proform 955r bicycle console problems"
The only part of the console that works is the light that moves around the track. The rest doesn't work. YOu can't choose a workout. It doesn't show you your speed, how far you've gone, or anything else. The handlebars also will take your heart rate. We just changed the batteries. Any suggestions?
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 11 Answers
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
Enter the diagnostic menu and ensure the "telemetry" option is enabled in the managers config menu.
Posted on Apr 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
Posted on Jun 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: My proform 515s Crosswalk treadmill works for a
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt. 4. After completing the steps above go to your local hardware store and purchase a can of silicone spray ( Pyroil, Napa etc ) attach the nozzle and proceed to spray length wise starting at the motor shroud to 2/3 down the deck repeat the process on the other side then re-tension the belt according to you owner's manual. Start unit and proceed to walk on it if the unit shuts down again then belt and deck needs to be replaced or your in the market for a new treadmill.
Posted on Jun 30, 2010
SOURCE: When I turn on the
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
New console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
Treadmill only hums when turned on, tread does not work
Hello, it seem there could be something jamming the tread mill belt or the transmission gears coult be broken. There is a very good possiblity that the electric motor has goine south, it doesn't work, or seeze up might have to be replaced.
GB...stewbison
Oct 19, 2011 | Cars & Trucks
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter...
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter don't light up. Help!
Aug 29, 2011 | 1997 Honda Accord
My pro form treadmill - panel lights come on but belt not operating? Any ideas how to repair or who would call out - Derbyshire area? Thanks
If the light are on and when pushing the console start button the oval track lights (on the console) should move. If not, then your console is bad. On most Pro Form consoles you have to replace the entire console. Individual parts are not available.
Jul 28, 2010 | Proform Exercise & Fitness
My Pro-form XP 185 U bicycle has a timing problem. It stops every 5 seconds, and you have to press the start button again. How do i fix this?
My pro form cardiocrosstrainer 800 has a timing, speed, and calarie
diplay problem. It does not work. How do i fix the problem with on the console display.
Jan 27, 2010 | Proform Cycling
Console buttons don't work,only ifit button works
Has anybody found the solution for this? I'm having the same problem on my 850T treadmill. It's really annoying..
Feb 14, 2009 | Proform 540ls Treadmill Walking Belt
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
