Question about GE Microwave Ovens
Ge range jbp76gv3ww
Broiler won't shut off
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My GE gas oven won't
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Jul 03, 2011
MicrowaveSvc
  • 9047 Answers
SOURCE: range lights on a over the range GE mirco wave
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Or you can buy and install a new control circuit board (smart board) from the Pros here, our favorite supplier.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Posted on Oct 18, 2011
Won't shut off
You may have a problem with a door switch or door switch mount, or there may be a shorted relay on the control board, which can easily be repaired.
Our help file on door switches is here, and the Advantium 120 service manual is here.
You can order GE parts from the Pros here.
Jun 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
GE jvm1653sh01 range lights won't turn off
Got a short at or in the switch assembly that is causing this and unit would have to be unpowered and checked to see if one or both switches are bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Power won't shut off when door closes
One or two micro switches are defective, "door switch"
Apr 02, 2012 | GE Profile Spacemaker Over-the-Range...
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
Advantium won't shut off
The problem is the microprocessor control board, professional should verify.
Mar 11, 2012 | GE Advantium 120 Convection/Microwave Oven
Turntable in GE Spacemaker does not work most times. If rotate manually, may work for a moment -- but won't stay on.
I think you have the worm gear worn. Even the motter is okay. It comes with all things together, so just replace the moter .
Thanks
Please rate me
Nov 13, 2011 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
My ge over the stove microwave works for a few minutes then shuts down for about 20 minutes before it will work again.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and order parts here.
Oct 17, 2011 | GE Profile Spacemaker Over-the-Range...
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
heatman101
Jul 03, 2011 | Microwave Ovens
I have a GE range JGB290MEN2BS. I relaced the broiler igniter p.n. WB13K21 My question is: should the ingniter continue to glow after the flame ignites. i assumed it would go off when the flame came on...
No, the igniter continues to glow. Current has to flow through the igniter to allow the main valve to open and allow the gas to flow. So the igniter will be on all the time while the broiler is operating.
Dec 25, 2010 | Microwave Ovens
Microwave Ovens Logo
13 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
