Question about Pioneer AVH-P3300BT In-Dash Receiver
Bluetooth menu I'm trying to connect my iphone via bluetooth and i can't get the bluetooth menu to come on. I try pairing and I get a message saying to check if the bluetooth unit is turned on on the reciever
3 Suggested Answers
  • 43 Answers
SOURCE: How can I get a Bluetooth adapter?
This should do the trick:
http://www.bestbuy.com/site/rocketfish-bluetooth-music-receiver/5654132.p?id=1218679203690
Posted on Apr 20, 2015
ameliawang93
  • 1001 Answers
  • Excellent Bluetooth Receiver,stable connectivity and remarkable signal stability.
  • Smooth call conversation and non-stop and clear music streaming creates enjoyable listening experience
  • Two-link: Enhanced Bluetooth signal can reach up to 15 meters in open space without obstacles and can be connected with two Bluetooth devices simultaneously
  • Universal Compatibility: Fully compatible with iPhone, iPod, iPad, Tablets, Other Smartphone, most speakers, TV, and radio, easily plugs into any powered PC speakers, Car & Home Stereo Sound System.
  • Small and Simple: Its outline feels like a mini iPhone 6, petite and charming, it doesn't need much space in your car; Simple buttons design, easy operation, you can get away from complicated operation of some other Bluetooth receivers.
Amazon com Charm sonic Portable Bluetooth 4 1 Receiver Wireless Multipoint...
Posted on Nov 21, 2016
Can't pair iPhone on 2005 BMW x5
did you mean via bluetooth? if yes please remove saved car kit devices from you phone and then try again with correct pass-codes
Sep 09, 2014 | Apple iPhone Smartphone
IPhone not pairring with parrot ck3100: I pressed "forget this device"
remove other paired devices on your device, may be the device has crossed the limit of phones it can connect.
start pairing fresh on both devices- phone and bluetooth device.,
Jun 06, 2017 | Apple iPhone 4S
Not sure how to connect phone to hilux bluetooth
The option for pairing bluetooth with phone is available in thephone's settings. Enable bluetooth under settings, and ensure that the bluetooth device is set to 'discoverable' or 'pairing' mode. Simply scan for devices from the iPhone via the bluetooth settings.
Nov 30, 2011 | Sony Ericsson Cell Phones
It cannot connect with mobile phone, I tried to use HTC and IPHONE to connect, all of these cannot search the signal from bluetooth? why? I also tried to turn on and off mobile phone and bluetooth for many...
Here is something to try on your iPhone. Hopefully it should fix your problem.
On the iphone, delete all the headsets you may have used from the UI of the iphone.
Turn off the headset.
Warm reset the iphone, press and hold the home and power keys on the iphone for 10s, the screen will go blank and the phone will reset.
While the iphone is rebooting, turn on the headset again and put it into pairing mode with the LED flashing red/white, red/white ...
Now when the iphone is ready, make it search for the headset.
When you see the "9xxPlantronics - Not Paired" entry on the iphone UI, then tap the screen where this message is displayed and the iphone will pair to the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 22, 2011 | Plantronics Discovery 975 (8164001 P)...
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
May 07, 2011 | RIM BlackBerry Curve 8520 Smartphone
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
Im trying to pair my iphone with my blueant but it keeps saying (make sure blueant st3 is turned on in range and ready to pair)
First off the device you are referring to is a ST3 and not a Z9. What you need to do is put the device into pair mode prior to searching in your iphones bluetooth menu, to do this with the device off hold down the green button until you hear a language loop. When you hear the language of your choice let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go to your Iphones bluetooth menu and select the ST3 and it should work.
Regards,
Rylan
Dec 04, 2010 | Blueant Z9 Wireless Headset
I have an iphone I have switch Bluetooth but can
usually the device or the iphone will prompt you with the passkey when trying to pair.
ie. start the connection process, the device says here is the passkey, the iphone will show a menu to put in the key, type it in, the devices pair up.
Jul 08, 2009 | Apple iPhone 3G
Iphone won't work with bluetooth in mazda 3 2010 My iphone shuts off whenI try to use the bluetooth system in my mazda 3
iPhone has had bluetooth since the first model in 2007. With iPhone OS/firmware 3.0 (free for all iPhone users), iPhones are fully A2DP compliant and link with Mazda bluetooth.
My current experience is with a 2010 Mazda3 and iPhone 3GS, where I get phone and iPod functionality via bluetooth (yes, without jailbreaking), though the steering-wheel controls are limited to play/pause and volume only.
Jun 12, 2009 | Apple iPhone 3G
Pioneer AVH-P3300BT In-Dash Receiver Logo
19 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
