Question about Refrigerators
Refrigerator compressor won't run
I have an Amana side-by-side refrigerator that wasn't cooling very well. The compressor/fan was running. I took the stuff out of the freezer and found the vent (intake?) on the bottom has completely iced up. So I took a hairdryer to it to defrost it. Unfortunately I forgot to turn the unit off and didn't notice the compressor turning off while I was defrosting it. Now the compressor won't turn on again. I've laid a cold towel over it for about 1/2 hour now, it feels warm. I'm guessing the overheat/overcurrent protection jumped in? But it still haven't restarted after 1/2 hour. I also checked the start relay and shook it. Doesn't seem to be loose inside. Did I break the compressor blowing hot air into the vent? If it is the overcurrent/overheat relay, does it reset itself or do I have to buy a replacement? Thanks for the help.
    Problem Solver:
  • 5 Answers
Plug it in. It may be in Defrost cycle, nothing runs when in defrost cycle. Amana's are famous for defrost terminators to go bad. The fan in the back should be running even if the compressor is bad. Do you hear a clicking in the compressor? If so the overload in the compressor is bad.
Posted on Jul 28, 2013
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
lenwest
  • 150 Answers
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    Amana refrigerator SQD23VW
    If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
    Apr 09, 2013 | Amana Refrigerators
    Amana - Top freezer model ATB1915HR. Freezer is not cooling. The fan is running. Tried increasing and decreasing cooling settings. Emptied and cleaned out.
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
    If your refrigerator is running but warm, then...
    Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
    Refrigerator Condenser Coil Cleaning Refrigerator Repair
    Refrigerator Troubleshooting Refrigerator Compressor
    Refrigerator Compressor Start Capacitor and Start Relay
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Aug 31, 2011 | Amana ATB1830 Top Freezer Refrigerator
    Freezer on side by side won't freeze ice creasm
    heatman101
    Aug 06, 2011 | Amana 22.6 cu. ft. Side-By-Side...
    Freezer is cold, fridge side is not. Fan runs, compressor seems to run. water puddle on the floor on fridge side. anything available for DIY?
    Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator
    Defrost Timer Problem
    Water Running in refrigerator from Freezer
    heatman101
    Jan 01, 2011 | Amana ASD2620HRZ Side by Side Refrigerator
    Amana model SXD25QA3W. Not cooling. Compressor runs.
    Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
    You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
    Good luck but likely 15-17 years old....... New one ???
    Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
    Frig is not cooling, fan is running but not the compressor?
    compressors thermal overload relay needs to b replaced , or starting and running capacitors to b replaced
    May 24, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    Amana ASD 2620HRZ side by side not cooling at all!
    if all of that is running your ref. should be cooling.can you hear your compressor running?or can you hear it run for a few seconds and click.If you hear a clicking noise the relay to compressor has gone bad,if it is running then you have a leak in the sealed system.
    Mar 08, 2009 | Amana ASD 2624 Side by Side Refrigerator
    Warm fridge
    how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
    Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
    My refrigerator
    is the compressor running?. check the compressor at the back side of the refrigerator.
    Feb 21, 2008 | Amana ABB1927DE Bottom Freezer...
    How to troubleshoot amana refridgerator
    the evap fan, fan by compressor and the compressor should all be running. if they are then more than likely a bad compressor, so junk it
    Oct 30, 2007 | Amana 22.6 cu. ft. Side-By-Side...
    Refrigerators Logo
    112 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
